Noise after fuel filter replacement.
Ok just replaced the fuel filter on my r56 coupe. Before starting the project I didn't have the car running with the seat and cover out so I'm not sure if what I'm hearing is "normal". After doing the job which was fairly easy I hear what I'm guessing is just the fuel flowing through the line. But it just seems loud. Like I said I didn't have the seat and cover out with the car running before starting so I'm not sure if the sound is normal. I did make sure all the new seals were seated before putting everything back together.
Watch "Normal sound after fuel filter replacement?" on YouTube |
Your timing couldn’t have been more perfect. I just now started doing my filter and was searching this forum for info. Here’s a quick vid I just posted after reading yours. Sorry for the vertical video:
My car sat overnight so I was hopping that would help. I just put paper towel over the hose when I disconnected it. Very little fuel come out, what did was caught by the towel. Worked great.
Originally Posted by S-2013
(Post 4371971)
https://youtu.be/d4kXyS1b3FQ Questiin: How did you relieve the fuel pressure before disconnecting the hose on top of the filter housing? But by the sound of your car, it's a normal sound I'm hearing. |
Yeah, they sound similar. I’m letting it sit over-night just to be on the safe side.
they starting up fine or ruining fine?
the fueling system in the mini are very noisy so sometimes its hard to tell whats going on sounds like air is getting getting push tho something does it smell like fuel |
Originally Posted by BigBoost
(Post 4372104)
the fueling system in the mini are very noisy so sometimes its hard to tell whats going on sounds like air is getting getting push tho something does it smell like fuel car started right up, no stumble or running rough. Took it for a test drive, drove as is should even under heavy load. Doesn't smell like gas. It just a little noisy. |
Sounds normal with that high pitch whine that a pump makes. As long as the top seal is on and no leaks or smells i thing you are fine, you can look at this DIY as a check list to make sure everything else was fine and done right. Also, the pump should prime when you unlock the door or open the door. Like a really quick high pitch noise.
https://www.northamericanmotoring.co...ilter-diy.html |
(Post 4372347)
