Schroth harness install - bolt attaching lab belt too big?
1 Attachment(s)
I just installed my Schroth harness in my 2012 JCW. The lab belt quick release that attaches to the factory mount on the floor does not allow the bolt to go all the way through. The bolts shaft is thicker right at the end not allowing it to go into the smaller hole of the Schroth mounting bracket. I tightended it all the way but it wont go all the way in do to its size.
Do I need another bolt like was provided for the rear mounting bracket. Or should I drill out the front bracket to have a slightly larger hole? Here is a picture of it fully tightened down but not threading all the way in. |
hrmm......i would think drilling the hole to a larger size would be a bad idea....you would be removing material and weakening the bracket.
and i can see how accidentally not choosing the right bolt would also be potentially unsafe. i think your best bet would be to give schroth a call and see what they recommend. |
Originally Posted by Mcameron
(Post 3708705)
Do you think I can use the harness this way for the time being? I have an autocross driving school this saturday and was really looking forward to having it for the event. I will give them a call tomorrow. I have their phone on the instructions.
Is this the r56 version or an older harness that you are putting in?
On my R56 with the new R56 harness the stock seat belt is next to the torx bolt head. The pictures in the instructions show it that way although the written description suggests the opposite. I wouldn't use it without the bolt properly torqued.
Do you think I can use the harness this way for the time being? I have an autocross driving school this saturday and was really looking forward to having it for the event. I will give them a call tomorrow. I have their phone on the instructions. in the event of a crash....by using ill-fitting hardware/ brackets, you will be putting excess strain on the assembly which may lead to premature failure. |
It's suppose to be for an R56. Real fricken bummer but your right... Ill remove it and call today. Hopefully it's just a matter of them sending out the correct part.
Should I call the vendor I bought from or HMS directly? |
Hey guys, mystery solved... I needed to put the bracket on the inside of the factory bracket not the outside.
