Help !!!! Smoke from under shift boot !!!!
So I just got done buttoning up my tpr2 head and ns1 cam install and retune.... I'm still working it out on the tuning side but it runs pretty good...
My car ran perfect with 0 issues before the install of the head and cam n tune... what could be causing smoke to come up out of that area ? My shifter lever was pretty warm even too.. do you think this could be caused by my exhaust heating up too much due to the crackle n pop tune ? It seems the smoke and heat are rite above where my resonator is underneath, I tried making as much space as I could between it and the heatshield underneath but in a 2in section I'm pretty sure it pressed against the heatsheild . But it was never an issue before so could the crackle n pop tune really be causing that much excessive heat in the exhaust ? I tried heat coating it too and my headers are wrapped. its a terrible stink burning smell too,very rancid smelling. help plz !!!!! |
Running too lean can cause excessive heat.. Some years have a box under the shifter, was yours removed?
Originally Posted by Da_Ghost
(Post 4558334)
I rigged this up and it worked enough to make it not smoke but it did still get a little warm in that area. I used the wood to pull down on the exhaust hanger that's above that plate, its just temporary as I find a better solution. would it be ok if I remove that box and possibly then be able to put in more heat shielding or atleast give it enough area for heat to dissipate better.. how loud or bad would my exhaust sound if i just deleted that resonator there with a strait pipe? lol or I hope that guy still is going to give me that free r56 exhaust, ille adapt that on and that'll fix all these problems . https://cimg7.ibsrv.net/gimg/www.nor...90fe73e224.jpg |
You mentioned your headers are wrapped. If you just installed it. It’ll smoke and smell for awhile until it burns off.
Originally Posted by Serafin
(Post 4558360)
I see this aftermarket , I can buy just the muddle section which then I can simple bolt up( might have to simply cut to length) but my pacesetter resonator is too large. Heres a pic of the smaller one like I need , my pacesetter is about 2x as wide as the one below( or modify and run r56 exhaust ) https://cimg8.ibsrv.net/gimg/www.nor...faa3f1994c.jpg |
