Bump bracket MOD?
Old Apr 24, 2007 | 04:12 PM
WorksMiniS's Avatar
WorksMiniS
Bumper bracket MOD?
I am about to purchase some O.Z. Ultraleggera's with 215/45/17 tires.
I have read up on this combination and understand that it may rub a bit. I have also read that the rear bump brackets can be modified to make them work.
Does anyone have pictures of this bracket mod. I would like to do this before i have a problem with the rub.
Thanks in advance.
Old Apr 24, 2007 | 07:39 PM
AntiqueCarNut's Avatar
AntiqueCarNut
The Ultraleggera's are ET37, so my setup is close to what you're planning to install.
I just installed a set of Enkei GTC01's (ET38) with GY F1's 215/45/17. I have the JCW suspension. Alex said that I may have an issue with the tires rubbing on the bumper bracket inner rear fender well plastic 'bump' at the rear of the wheel well, but, so far I have not experienced any clearance issues. My guess is that you'll probably be OK, unless your car is lowered more than about 1".
Old Apr 24, 2007 | 09:35 PM
WorksMiniS's Avatar
WorksMiniS
I have the JCW suspension too. I just wanted to get it done while i had the car in the air with the wheels off.
The shop I use is very user friendly.
minieater
Oct 28, 2015 02:15 PM
B1mm3r101
Oct 1, 2015 06:22 AM
rt808
Sep 29, 2015 03:15 PM
krohm
Sep 28, 2015 12:16 PM
