R56 Auto Sport Button wiring
Old Apr 19, 2007 | 06:44 AM
Coffeeman's Avatar
Coffeeman
I was browsing the Jeep forum, and came upon a post where a time delay one shot relay was used to turn on the heated seats, when the Jeep was started. This got me thinking about using the same setup to enable the sport button, automatically, when the MCS was started. The original Jeep thread link is below...seems like the only trick would be to connect to switched 12volts to initiate the sequence, then parallel the relay contacts to the sport button contacts.
http://www.jeepsunlimited.com/forums...t=remote+start
Old Apr 19, 2007 | 06:53 AM
djam43's Avatar
djam43
You would first need to determine if the OEM switch is Normally Open or Normally Closed, Momentary or Maintained contact.
Old Apr 19, 2007 | 06:57 AM
Coffeeman's Avatar
Coffeeman
Agreed, but since the OEM sport button switch does not have an on/off detent, I am pretty sure that it is momentary. This would be consistent with BMW electronics typical method of wiring.
Old Apr 19, 2007 | 10:15 AM
IamRascal's Avatar
IamRascal
You'd have to test to confirm but you should be able to wire it in with the run position of the column switch. With the push button start it would be dirt easy. The bigger question is if there is a time delay between when the computer is able to accept the input and the car starts.
Truthfully this is probably a lot more work than its worth. But in the winter the heated seats would be a blast.
Old Apr 19, 2007 | 11:16 AM
R56MCS's Avatar
R56MCS
Someone in the UK on the mini2 site has done this. Apparently it was'nt too difficult.
Dec 23, 2015 10:36 AM
khumpert
Nov 30, 2015 11:48 AM
jziran
Aug 24, 2015 04:50 PM
yashmack
Aug 15, 2015 03:11 PM
