Noisy brake pedal?
Old Apr 11, 2007 | 02:43 PM
Rennie's Avatar
Rennie
Noisy brake pedal?
I'll start off by saying that driving my 2007 MC is a lot different than driving my 2005 MC. It's taking me longer to get used to the R56 than it did my R53.
Now to my question. Does your R56 have a noisy brake pedal? Sometimes it clicks as I remove my foot and sometimes it makes a slight clunking sound. And the pedal feels very different from the R53; it's hard to explain, but I think I can feel it when it "clicks" and "clunks". Have other R56 drivers experienced this? Because if you haven't, I'm bringing it in to the dealer as I find it annoying. But if it's normal, I guess I'll just have to get used to it. Oh, I'm not sure it matters but I have an automatic.
Old Apr 11, 2007 | 03:07 PM
djam43's Avatar
djam43
How many miles have you on this Mini.?
Old Apr 11, 2007 | 03:15 PM
Rennie's Avatar
Rennie
Around 600.
Old Apr 11, 2007 | 04:14 PM
Gold88's Avatar
Gold88
Yes, mine makes the same noises you are describing. I've just thought it was due to electronic brakes.
Old Apr 11, 2007 | 04:45 PM
Rennie's Avatar
Rennie
Thank you for your reply. Now it's just a matter of getting used to it.
Old Apr 11, 2007 | 06:49 PM
Gold88's Avatar
Gold88
Old Apr 15, 2007 | 11:36 AM
Gold88's Avatar
Gold88
Just curious. I have about 900 miles now and I don't notice any more noise from my brakes. Have yours quieted down any?
Old Apr 15, 2007 | 11:47 AM
Rennie's Avatar
Rennie
I haven't driven my car since Wednesday so I can't really answer that. I'm hoping that since you don't hear the noises anymore it's a matter of the pedal loosening up. I'll be driving it again tomorrow and most of the week, so I'll see if I notice any change. Thank you for the update!
Edited to add, I still have less than 700 miles on the car, so if the noise does go away, maybe it's too soon.
Old Feb 3, 2010 | 04:37 AM
rduke222's Avatar
rduke222
SO, I have a 2010 S with about 3000 miles. My brake pedal makes similar noises.
When the pedal is released suddenly, there is a slight whooosh sound and a clunk as the pedal arm reaches its stop. The whooosh and clunk can be prevented by keeping my foot on the pedal and gently returning the pedal to its stop point. I don't recall that the pedal made this noise before now.
I haven't made it to the dealership yet to get their opinion of this noise.
Since the brake system otherwise functions normally, I don't know if this a problem or a normal brake pedal sound.
Anyone have any ideas?
Old Feb 3, 2010 | 01:42 PM
ecupip's Avatar
ecupip
Mine does the same thing. It sounds to me as if they don't even have a bump stop for the pedal when released.
Old Feb 3, 2010 | 02:05 PM
rduke222's Avatar
rduke222
Exactly!
If I turn the stereo up I don't hear it but it irritates me.
I'm going to take the car to the dealership to see what they have to say.
There should be a return stop that can be adjusted.
The problem is...I don't trust dealer service departments.
I'll post what happens.
Old Feb 5, 2010 | 10:45 AM
MINIDean's Avatar
MINIDean
OK guys...There is nothing wrong with your MINI's and no need to waste your time taking it to the dealer. You are simply experiencing the the Hill Hold Function of your brakes. I LOVE this feature.
Your MINI senses the incline of a hill using a sensor in the Dynamic Stability Control yaw sensor. If your are facing up hill and release the brakes, after about 2 seconds you will hear the brake pedal click or may feel it. Same goes if you are facing down hill and are in reverse. This is to hold your MINI in place so you can get started without rolling forward or back.
You'll also notice the sound/sensation this if you're in neutral, have the clutch and brake held then place your car in gear.
It's a normal characteristic and nothing to be alarmed about. The first generation MINI did not have this feature.
Old Feb 9, 2010 | 01:24 AM
rduke222's Avatar
rduke222
-snip
Thank you for your reassuring words. I agree with you about how nice the the Hill Hold Function is. I love it too. The sound I tried to describe is not related to this feature. The sound I am referencing is created when the brake pedal reaches its full return stop position.
I found an illustration of a brake pedal mechanism (see below). Note the "pedal stop adjustment nut" at the superior aspect of the brake pedal arm just above the spring. This is not a Mini Cooper but it's pretty close. I can feel something like the illustration if I follow the brake pedal arm with my hand. I suppose I could fool with the adjusting pin myself but if the adjustment affects the master cylinder retraction position or prevents excessive snap ring banging or whatever..., I'm going to let the dealership adjust it. Brecht is giving me a loaner while they evaluate it. I'm pretty sure it's an adjustment that takes about 5 minutes but I'll take the loaner and hit Valley View. {My wife got a Royal Flush with 5 quarters in last week! $1000}
I'll let you know what Brecht says/does.
The brake pedal should have an adjustable return stop on it when a strong pedal return spring is used. This prevents the master cylinder from excessively banging the snap ring stop inside the master cylinder bore (visible under the rubber boot). Adjust the stop so the pedal stops returning at the point when the master cylinder piston retracts against the snap ring,
Figure 1
Old Feb 10, 2010 | 11:49 AM
flintdragon's Avatar
flintdragon
mine does the same thing. Keep us updated...
Old Feb 10, 2010 | 01:01 PM
Robin Casady's Avatar
Robin Casady
I've never noticed the noise you refer to in my 2007 R56 MCS, but things may have changed since then.
I did find that I didn't like the way the brakes grabbed. It felt over-assisted like a Buick my Mom once owned. After a couple thousand miles I got fed up with the amount of brake dust the OEM pads generate and switched to Carbotech 1521 Bobcat pads. The brake feel (modulation) improved greatly with these pads.
Old Feb 11, 2010 | 05:35 AM
ecupip's Avatar
ecupip
Mine is not the hill hold function as it is an Automatic. There is just no significant bump stop for the brake pedal.
Old Jun 4, 2011 | 09:56 AM
ballandchain's Avatar
ballandchain
Anyone ever find out what this comes from? My 09 MCS w/ 23000 miles on it started to do this recently. It "pops" at the last inch or so of the return back to its normal resting position.
Old Jan 16, 2012 | 01:18 PM
budoboy's Avatar
budoboy
I looked at my '09 Clubman S today as it was making the same noisel. Looks like everything is attached fine but when you move the brake pedal it clanks. Seems like it needs a rubber stop or some insulation to keep it from clunking. Just a bad design I think. I have 21K
Old Mar 4, 2018 | 05:15 PM
1004ron's Avatar
1004ron
Search result brought me here, but unfortunately no solution.
My wife's 2012 Cooper Hardtop has 28K miles on it and been doing that since we got it.
With a mirror and flash light I've checked the pedal mechanism and don't find any bump stop.
Every time you lift your foot off the brake it clunks as it returns to its rest position.
Old Oct 5, 2021 | 01:46 PM
matt01's Avatar
matt01
Drove my wife's Mini today and found this thread searching for a cure to the annoying brake pedal return clunk noise on my wife's R59. Can't believe she hasn't complained before. Got to get a flashlight out and see what can be done. Driving me nuts.
thadscottmoore
Sep 25, 2015 10:07 AM
tylewis
Sep 6, 2015 01:07 PM
wildwestrider
Sep 4, 2015 06:25 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
Sep 3, 2015 02:06 PM
