Slammed look solution from CROSS
Being that the MINI is suspension travel challenged, achieving the "slammed look" while retaining drivability has been impossible. All you end up doing is driving on the bumpstops and damaging the dampers. CROSS has a solution with their MINI Competition coilover system.
What makes it possible is that both front and rear ride height adjustability is independent from the spring perch. Thus, adjusting ride height does not compromise the spring rate or rebound and compression of the damper.
CROSS MINI Competition coilovers systems are a perfect balance of street, luxury, and performance.
See the DMH web site for further details.
bradstyle
Oct 1, 2015 11:15 AM
