R56 r56 Engaging point.
Old Mar 22, 2007 | 12:37 AM
heyjay1428's Avatar
heyjay1428
r56 Engaging point.
well i have a r56 (PICTURES TO COME SOON :D) and it seems as though the catch point is very late..... is it me (being a new stick driver), or is it much earilier on.... for smoother shifts. i have to let go of the clutch almost at the very end. :P.
Old Mar 22, 2007 | 06:15 AM
R56MCS's Avatar
R56MCS
Mine is in the middle of the pedal travel, I am sure you can have this altered by adjusting the clutch cable.
this said you will get used to it quickly.
Old Mar 22, 2007 | 06:36 AM
Ryephile's Avatar
Ryephile
This would be very tough to do since the MINI's clutch pedal is strictly hydraulic!
With the R53's clutch, from the factory it would start engaging very low to the floor, then as it wore out [over the next 50-150k miles] the initial engagement point would rise closer to the middle/top.
With the R56 clutch, it seems the pedal engagement area starts in the middle. Only time will tell if it shifts over time like the R53's stock clutch.
All that said, the clutch is very "German" in feel, meaning it has lots of modulation, and definitely not a "switch" like most race clutches, and to some extent most American cars' clutch feel.
Since you're new to manual transmissions, everything is going to feel weird for a while. You'll get used to it.
Old Mar 22, 2007 | 07:25 AM
msmith81's Avatar
msmith81
If it's a hydraulic assembly, it should be adjustable. Hence why some people have a clutch that begins to engage at one point, and others have one that engages later.
Old Mar 22, 2007 | 07:37 AM
JohnBLZ's Avatar
JohnBLZ
Mine feels like it catches towards the top end of things, very different feel from any domestic stick I've driven but I think it should be a tad easier for a manual newbie to drive as they typically let the clutch out before they give it enough gas...
Old Mar 22, 2007 | 07:43 AM
dneal's Avatar
dneal
I think he meant that it would be hard to adjust the cable, since it's a hydraulic system.
BritBoy's Avatar
BritBoy
Yeah, the clutch definitely does bite very high. I noticed it as all our cars are manual trans and when I get out of the GTi and into the Mini I really notice the long pedal travel.
Old Mar 22, 2007 | 07:47 AM
dneal's Avatar
dneal
I've experienced it a lot in japanese cars, to the point that I'm used to clutches doing that. Depending on where the clutch actuates internally, it can be difficult to adjust; and some are self-adjusting.
Now if it was the old '69 Ford 3/4 ton doing that... I'd be checking the linkage.
Old Mar 22, 2007 | 07:55 AM
AliceCooperWA's Avatar
AliceCooperWA
I have no idea on the r56, but on the r53, there is no way to adjust the clutch. I would assume it is a similar type of hydrolic setup on the r56.
Old Mar 22, 2007 | 08:01 AM
Loui's Avatar
Loui
Clutches are expensive to replace, and can be ruined in a few thousand miles. I would suggest a couple of driving lessons. The essence of using a stick and clutch is smooth shifts.
Old Mar 22, 2007 | 11:57 AM
Robin Casady's Avatar
Robin Casady
Are they really that fragile these days? The original clutch in my Integra has 120K miles on it. I kept asking the dealer to check it and its fine. How do you ruin a clutch these days? In a '57 Alfa Romeo, a cousin managed to trash the throw-out bearings. Is that still a vulnerable part?
Old Mar 22, 2007 | 12:40 PM
dwdyer's Avatar
dwdyer
Hard shifting isn't as likely to wear out a clutch these days as riding it will.
BTW -- has anyone else noticed that it's easier to smooth shift with sport mode on? That one's puzzling me.
Old Mar 22, 2007 | 12:46 PM
JohnBLZ's Avatar
JohnBLZ
I have as well... found it odd.
Old Mar 22, 2007 | 01:24 PM
Peef's Avatar
Peef
No doubt about it - smoother shifts in Sport mode.
Old Mar 22, 2007 | 01:39 PM
Skuzzy's Avatar
Skuzzy
The only problem I had with the standard was the clutch pedel requires so little effort the weight of my leg would depress it. So I am forced to hold my leg up off the pedal. A little awkward. I hope I can find a clutch return spring to add and bolster that up a bit.
Old Mar 23, 2007 | 08:07 AM
Loui's Avatar
Loui
Yep, riding the clutch will wear it out in no time.
Old Mar 23, 2007 | 08:16 AM
mauberley's Avatar
mauberley
I did notice that when I was playing around in an R56 at the dealer a couple of weeks back. There seems to be more resistance in the clutch on my R53. The travel of the pedal seems different as well.
Old Mar 23, 2007 | 08:20 AM
swissarmybottle's Avatar
swissarmybottle
... you must have a heavy leg
kidding.
to stay on topic, although this is my first ever manual car (i stalled so many times... over rev'd it from 0 too many times... tried to switch gears without clutching too many times... etc) i blame the location of the catch point. I swear, it's pretty much right at the top... so i think, "yes, it's on now... i could just let go of the.... <<stall>> "
i do agree with some of you about the "sport-mode" smooth shifting suaveness. I like it, but I'm just worried sport-mode is bad on gas mileage... is it?
Old Mar 23, 2007 | 09:18 AM
Skuzzy's Avatar
Skuzzy
Hehe swissarmybottle. Imagine my shock when I went to shift and the clutch pedal stayed on the floor when I relaxed my leg to shift (thought I was going to blow the engine on that missed shift). I actually had to pull my foot up to engage the clutch. The pedal would not come up while my foot/leg was resting on it. I am tall (6'4"), but I am also slender (205 pounds).
Makes it tough to shift quickly. The engagement point was about halfway up. About 3/4 was full. Pretty linear. I thought it was a bit too long though. I am used to linear engagements, but with slightly less pedal travel.
Old Mar 23, 2007 | 09:47 AM
z3bum's Avatar
z3bum
The new transmission is a Getrag, what BMW uses in their 1 and 3 series cars. It should have a very long life and definitely results in (for me) very smooth shifts.
Curiously, the sport button does affect the startup for me. In non-sport, there is a little lag in first gear when you first let out the clutch and hit the gas. In sport mode the MINI takes off instantly. However, I found that if you blip the throttle as you go into first and let out the clutch smoothly, it takes off nicely.
It's all good, loving the new MINI.
rtk90
Aug 29, 2019 09:08 AM
newowner
Sep 15, 2015 07:18 AM
Sep 3, 2015 02:06 PM
