Getting new wheels/Brake Dust
Old Mar 5, 2007 | 02:28 PM
Rossii's Avatar
Rossii
I'm thinking of getting some ASA R1's since I really like the look. However, I'm thinking they would be a pain to keep clean. I've been reading that waxing the wheels would help. Is there something else I can do before putting them on?
Cheers!
Old Mar 5, 2007 | 04:02 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Cheers!
ASA R1 is which finish?
Silver with Machined lip
Black with Machined lip
Chrome plated
Probably the finish to worry the most about would be the Chrome plated. Corosion can occur and ruin and pit the chrome- you must keep it clean.
I have seen chrome get messed up in less than a year if you don't regularly clean the brake dust off.
Waxing the wheels only helps a little. Wheelwax is supposed to help but it doesn't last. Smells good.
Changing brake pads to something that gives less brake dust is probably the best thing you can do especially for the front brakes. Mintex Redbox and EBC Green pads are common choices. Both have less dust than stock pads and perform OK for street use. The Mintex pads are half as costly as the EBC greens.
Keep your wheels clean about once weekly is OK but over time the finish will be beat up and dull. Takes about 2 to 3 years.
Black would be easy to neglect and still look OK but you have to clean it now and then.
The R1's spoke pattern is not the most friendly but it's OK. Some people use a brush wheel cleaner with a handle that seems to work.
Old Mar 5, 2007 | 05:23 PM
mini552's Avatar
mini552
I have BBS RGFs which are similar design, and found that changing pads to Hawk ceramics (Mintex Red Box would work as well) really cut down on the brake dust. For cleaning, I use a brush made for the purpose (I think mine came from Griot's). I like to actually use a second, small bucket of the same wash solution & water, dedicated for the wheels - don't want to get the brake dust & other grime onto the wash mit that you use on the rest of the car. With a light coat of synthetic wax/glaze occasionally, the brush and soapy solution cleans my wheels just fine, even w/o a spray-on wheel cleaner.
Old Mar 5, 2007 | 07:26 PM
Rossii's Avatar
Rossii
Chrome plated
I was thinking of the Silver w/machined lip. Black was a thought but the silver looks much better to me. I currently wash my stock wheels once a week but even then its hard keeping them clean. I think new brake pads are my best bet. Thanks for the info
BernieCoop
Sep 10, 2021 03:15 AM
Doc Pain
Mar 10, 2021 04:50 AM
gnhovis
Sep 28, 2015 04:07 AM
Tires, Wheels & Brakes
Sep 10, 2015 03:10 PM
Sep 4, 2015 09:23 AM
