Headlamp problem
Old Feb 26, 2007 | 07:03 PM
Chili R's Avatar
Chili R
Headlamp problem
I have an 04 MCS with the xeon headlamps and lately on first start up they seem to shine too low. The beam shines approx. 5ft. in front of vehicle with a shadow cast to it. I can turn on high beams and it only shines to 10Ft. Then after about 1/2 hour driving it seems to correct. Also on start up it does not do the "Fancy Lite Dance" . Does anyone understand what is going on ?
Thanks in advance
Old Feb 26, 2007 | 07:44 PM
Phantom's Avatar
Phantom
take it in for sevice assumuming you still have the warranty THEY should replace the headlamp assembalies so I"ve been told as the 04+ have this issue.
Old Feb 27, 2007 | 08:06 AM
joey1320's Avatar
joey1320
the lamps should adjust the height on their own, may be a bad sensor.
Old Feb 27, 2007 | 08:19 AM
Eric_Rowland's Avatar
Eric_Rowland
Yep, either a sensor or motor (likely a sensor, if both lights are acting the same.) If they're not doing the happy dance, they are not happy.
Warranty is good.
Going out of warranty is scary.
Old Feb 27, 2007 | 08:57 AM
JCW Driver's Avatar
JCW Driver
I'm having the same issue. Car goes in to Rasmussen MINI tomorrow. Still warranted for a couple months, thankfully.
As I understand it, the leveling sensor is on the rear suspension assembly.
UncDeo
Nov 4, 2019 04:08 AM
tylewis
Sep 6, 2015 01:07 PM
mimaal
Sep 4, 2015 09:09 AM
Sep 3, 2015 01:45 PM
Sep 2, 2015 09:05 AM
