brake ducts
Old Feb 23, 2007 | 09:19 PM
HC0624's Avatar
HC0624
brake ducts
I finally pull the trigger on these JCM brake ducts last week, and here they are! They are for the standard MCS bumper only, not the aero bumper. I’m thinking about duplicating another set for my friend. If it is not hard, I will make more. Let me know if you are interested, so I can get an idea...
JOHN
Old Feb 23, 2007 | 09:28 PM
MINICHEF's Avatar
MINICHEF
YES, INTERESTED
Old Feb 23, 2007 | 09:43 PM
billie_morini's Avatar
billie_morini
Does the intake go into an existing bumper hole or do you make the holes?
Old Feb 23, 2007 | 09:59 PM
fafnir's Avatar
fafnir
if you're hand making these can you make these for the R56?
_
Old Feb 23, 2007 | 10:35 PM
HC0624's Avatar
HC0624
I don't think I have that much time in hand to make a set of the R56. I will see what I can do, but I can't promise anything...
Have to make a bigger hole from your fog light hole...
JOHN
Old Feb 23, 2007 | 11:18 PM
billie_morini
O I C.
tanx
Old Feb 24, 2007 | 07:57 PM
markp's Avatar
markp
Rush "Roll the Bones"
I'm interested... How much???
Old Feb 25, 2007 | 05:13 AM
vader's Avatar
vader
I need these NOW!!!!..... Please don't be teasing us.
Anxiously awaiting details!!
Old Feb 25, 2007 | 07:53 AM
HC0624's Avatar
HC0624
I will try to make a mold as soon as I have time (end of march).. and give your more info about it.
I would say about 250usd to 300usd max.
JOHN
Old Feb 25, 2007 | 11:19 AM
toddtce's Avatar
toddtce
While any cooling can be a good thing I'd have some reservations on the output of the duct. They appear to blow on the inner side of the rotor. This is not the best of solutions as it causes an temperature inbalance in the rotor which in turn can effect pad wear, rotor wear and perhaps a bending of the rotor if extreme. If they are cupped onto the caliper body that's not quite so bad as it will keep the caliper fluid from boiling.
The best and proper place for the air flow to be distributed is at the hub center inside the rotors far side opening. This not only distributes the air into the vanes of the rotor where it belongs for cooling but also helps cool the wheel bearing which will run hot too.
Old Feb 26, 2007 | 06:23 AM
LEPRACHAUN's Avatar
LEPRACHAUN
Todd, could you please help me and clarify "..the rotors far side opening." Would this be the outside edge? I've seen the replacement backing plates with the hose attachment tube. This seems to place the air at the inside face of the rotor too.
Old Feb 26, 2007 | 07:35 AM
toddtce's Avatar
toddtce
Here's a rather well done one. With lots of pics!
https://www.northamericanmotoring.co...te=1&p=1392205
Old Feb 26, 2007 | 09:08 AM
curv872's Avatar
curv872
The above link doesn't work???
Old Feb 26, 2007 | 09:47 AM
toddtce's Avatar
toddtce
http://zhome.com/ZCMnL/PICS/BrakeDucts/ducts.html
Tires, Wheels & Brakes
Sep 10, 2015 12:27 PM
Sep 10, 2015 10:52 AM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 4, 2015 09:23 AM
PelicanParts.com
Sep 3, 2015 03:22 PM
