THE SCOOP....NAM SAVES$$$.by Palo Uber Mini London
Old Feb 18, 2007 | 08:27 PM
Carol@PaloUberMini.com's Avatar
THE SCOOP,.designed by Palo Uber and engineered by our automotive specialist in Germany, is the only full hood induction scoop with CERTIFIED air flow dynamics, over the OEM trim ring vent and the other two scoop manufacturers. Our patented design, unlike all others, ntraps the air and funnels the air in a gradually diminishing tunnel, delivering the air where you need it. At just 40 mph., THE SCOOP increases your air flow over the others by 147 %, that is what counts. The increased flow is 97.89% smooth air, not disruptive tumbling and eratic air trying to find it's way downwards from a wall impact diversion method. The maximum increase is slightly over 200 %,.
Tested and reviewed by NEW MINI MAGAZINE, they said.."after installing THE UBER SCOOP, we drove from London to Southampton with the temperature well into the high (90 F.) levels on a July afternoon...the intercooler temp. gauge was at all times at least 3* cel. lower than it normally runs, even with the heat wave we were experiencing... we could feel significant performance improvement over the before state...extremely well made...well worth the money, no doubt about that...spot on for Palo Uber Mini..in our opinion this is by far the best scoop we have tested...."
Each scoop is meticoulously molded from the highest grade of automotive fiberglass and gel coated in black. Then each unit is preped and finished in the Palo Uber shadow line black ( similar to the trim molding ) which is a propriatary finish which is actually a baked finish providing years of maintanance free service and also reduces heat. Stainles steel screws and washers secures the scoop in place which simply replaces your existing OEM trim ring. Complete instalation time in less than 15 minutes. If you want to significantly reduce your intercooler temperature and increase your horse-power and boost, this is the documented, tested and independently reviewed best full hood induction scoop on the market.
NAM members save $80.00 when purchasing THE SCOOP. Go to our web-site, www.paloubermini.com , then go to the online store, then scroll to NAM KIT# 9, and place your order, Photo,s and additional information on the online store and gallery. $235.00
Old Feb 22, 2007 | 08:01 PM
Cab, when you recieve your scoop there is a flow chart included done by a calibration and measurements lab. It compared our scoop tp the m7,oem trim ring and alta unit. ours outperformed all in terms of air intake increase and outperformed all in regards to smooth air delivery, which is an overlooked but essentail component...bryce
Old Feb 24, 2007 | 05:12 PM
The nam price with the oem mini body colour with clearcoat is nam kit #10, the nam prive for the scoop finished in our shadowline trim black is nam kit #9.
Go to www.paloubermini.com , and then go to the online store, then scroll to find the nam kit section and puchase nam kit 9 or ten. ..thanks, hope this helps..bryce
Old Feb 24, 2007 | 08:11 PM
shep, missed your call, call back. we have code 668, right?
Old Mar 4, 2007 | 07:00 PM
tested the best smooth air induction on the market..worlwide
Ben, thanks for the email... the scoop has been independently tested and it out-performs the other two well known scoops as well as the OEM trim ring.
They tested our scoop against the air-block method scoop, which is similar in design to the subaru scoop, which blocks the air and then tries to force the air downwards, thus they refer to this as the block method. It does work better than the oem trim ring, but the block method creates incredible turbulance and looses 1/2 the air it blocks back out the front of the scoop, while the remainder is extremely turbulent. Ours, traps the air in front and funnels the air through a gadually diminished opening , delivering 97% smooth air, and over 147% more air than the block method.,,,more smooth air, cooler it gets....the more hp and boost increase you achieve....bryce
Old Mar 10, 2007 | 04:00 PM
Painted Scoops
Dan, cant reach you by tele...your Uber scoop and the venturi scoops went out today, saturday, fed-ex..they look great....some other artifacts also,
happy b-day...........bryce
Wohnson89
Jun 10, 2020 04:53 AM
OutMotoring
Aug 10, 2015 12:15 PM
marendt428
Aug 9, 2015 06:54 PM
kwijmbo
Aug 5, 2015 09:00 PM
