Drivetrain The Detroit Tuned Bypass Valve
Old Jan 17, 2007 | 06:03 PM
djdport66's Avatar
djdport66
Has any installed this on an older MCS? Thoughts?
Thx
Old Jan 17, 2007 | 06:04 PM
jeffc's Avatar
jeffc
7th Gear
I have a 2002 MCS and love it.
Old Jan 17, 2007 | 06:05 PM
70spop's Avatar
70spop
I will soon.
Based on Jeff's recommendation, I just ordered one for my '03 MCS the other day. I'll let you know after I have it installed.
Old Jan 17, 2007 | 06:29 PM
mbcoops's Avatar
mbcoops
Another question about the detroit tuned BPV (hopefully this will continue the conversation djdport66 started and not be a hijack):
My BPV failed as I was merging onto the NJ turnpike at about 70mph; it was first very scary and second very frustrating.
Is the detroit tuned BPV safer in anyway? I know it's a strengthened stock BPV, but does that mean it's less likely to fail and get stuck like mine did? I ask because it took a little fancy footwork to make sure the people behind me didn't hit me when mine went, and I don't want to imagine this happening on the track.
I'd gladly pay the dollar price and lose the 1or2 mpg if this is a safer option.
Thanks!
mb
Old Jan 17, 2007 | 08:44 PM
70spop's Avatar
70spop
My stock bpv died about a year and a half ago. Not as dramatically as yours, but I noticed at some point that the car was a real slug. I was having a hard time keeping up with Coopers on a club run. I ended up driving the car for probably six months like that. The local dealer said nothing was wrong with it when I had it checked, and it's not like the car didn't run, just had about 90hp is all. It turns out the return spring had broken and the bpv was stuck open. The beefier return spring on the DT unit is one of the main things that sold me. I count that as being "more reliable". I also like the fact that they have modified it to closed completely, and that the heftier spring means that it will be a bit more reluctant to open. I'm looking forward to getting mine and having it installed.
Old Jan 17, 2007 | 09:29 PM
MarioKart's Avatar
MarioKart
Vendor
I love mine, it's a must for the older Mini's. It gave my car smoothness on take off and got rid of the YO YO that i could never get rid of no what other mods i did. It is easy to install and is a cheap mod. It also gave me one more psi of boost.
Mario
Old Jan 17, 2007 | 10:08 PM
motonikki812's Avatar
motonikki812
I just installed one on my JCW car. I must say it is the best/most noticable engine mod I have done to it so far.... It really made the car much more crisp and responsive. The boost hits harder for sure and pulls longer. It feels like the car has more overall hp although throughout the rpm range.
As far as installation goes.... I would use Dr O's recommendation of removing 2 of the studs on the intake horn and installing much more simple bolts. You decrease the chances of damaging the supercharger intake tube. You will also appreciate it later when you ever have to remove these parts again. Just search "by pass valve" and you should find Dr. O's instructions. I took this recommendation and am glad I did.
Bottom line is Get It! You will be glad you did.
Old Jan 17, 2007 | 10:17 PM
70spop's Avatar
70spop
Glad to here that!!! Mine's a JCW, too, and I often feel like I'm not getting all out of it that I should be.
Old Jan 18, 2007 | 05:07 AM
djdport66's Avatar
djdport66
Wow, that slug feeling....that's where I am at. Coming off an apex back on the throttle the car just won't pull like I am used to...
So the installion is a DIY job? Any special tools need for this part? I will also check Dr. "O's" recommendations. Thanks for the insight gang.
THX,
DJDport66
Old Jan 18, 2007 | 07:13 AM
JPMM's Avatar
JPMM
Quote...."So the installion is a DIY job?"
When I looked into it it seemed it was not. You have to loosen the front of the car and move it out of the way. And there is more.I was wondering if the stock one was designed to allow the supercharger to "free wheel" during cruising and other times. For less stress and better MPG's .Then as boost rises the boost pressure helps close the vlv.
Old Jan 18, 2007 | 01:15 PM
RedSkunk's Avatar
RedSkunk
Anyone think it'd be worthwhile on an +05?
Old Jan 18, 2007 | 01:24 PM
MarioKart's Avatar
MarioKart
Vendor
Depends if you car has that YO YO affect when it takes off.
Old Jan 18, 2007 | 01:25 PM
hornguys's Avatar
hornguys
It worked well on my '03. I also wonder if there's an advantage to using it - in my case - on an '06.
Old Jan 18, 2007 | 03:40 PM
mbcoops's Avatar
mbcoops
I guess that was the jist of my question - my car is an '05, and my SA admitted to me that the stock BPV is not a well-made piece. It stands to reason that the detroit tuned unit is better because the spring is strengthened, but what do I know?
mb
Old Jan 18, 2007 | 04:07 PM
RedSkunk's Avatar
RedSkunk
mm. And if it adds a pound of boost... There was one for sale the other day for $50. Might be worth it...??
Old Jan 21, 2007 | 03:28 PM
Standard's Avatar
Standard
This bypass valve won't make any noise different than stock??
Old Jan 21, 2007 | 06:16 PM
dmh's Avatar
dmh
An unfortunate byproduct of the DT bypass valve is it will increase the IAT.
Old Jan 21, 2007 | 06:24 PM
Crashton's Avatar
Crashton
What is IAT ??
Old Jan 21, 2007 | 06:27 PM
dmh's Avatar
dmh
Intake air temperature; measured in the intake manifold.
Old Jan 21, 2007 | 06:42 PM
Crashton's Avatar
Crashton
Thanks for the fast reply. Is the IAT higher because of the 1 pound of additional boost? I know when you squeeze air it gets hot.
Old Jan 21, 2007 | 06:57 PM
dmh's Avatar
dmh
I don’t know anything about additional boost but I do know about the increased IAT. (I measure boost and IAT directly in the intake manifold.)
Under certain engine operating conditions the intake air is intended to go directly into the intake manifold. With the DT valve it is instead directed into the s/c. Hence, hotter air and less performance.
Old Jan 22, 2007 | 07:27 AM
djdport66's Avatar
djdport66
If understand what your saying, sometimes you don't really want the additional boost? Would it also seem to reason that the computer would need different programming to deal with the fuel/intake mixture? Sounds like a bad idea to alter the spring.
Old Jan 22, 2007 | 08:00 AM
dmh's Avatar
dmh
The DT bypass valve is a popular NAMer modification. But from my perspective it is not a wise idea. I have an entire list of poorly thought out modifications but that is for another thread.
Old Jan 22, 2007 | 09:48 AM
mbcoops's Avatar
mbcoops
Don - I (and others) appreciate your opinions and the work you do to support them. It's nice when alternatives are offered. That said, what would you recommend? I don't need to do anymore testing to know that the stock BPV is not something I'm comfortable with on the track, especially with how dramatic its failure was for me on the street. So what should I do? I'm not comfortable with the stock, and you see the DT BPV as "not a wise idea," so what's one to do? Risk it with the stocker?
mb
Old Jan 22, 2007 | 09:54 AM
dmh's Avatar
dmh
Want better throttle modulation on the track? Then my opinion is to use the stocker.
