PC Pad Cleaning
Old Jan 10, 2007 | 02:15 PM
mcdbrendan's Avatar
mcdbrendan
PC Pad Cleaning
What is the best way to clean a pad after polishing? I get my big DP order soon and want to make sure I have everything under control when i get it.
Old Jan 10, 2007 | 03:33 PM
bamatt's Avatar
bamatt
I hope somebody tells you the answer so I won't have to ask when I use mine for the 1st time
Old Jan 10, 2007 | 03:35 PM
mcdbrendan's Avatar
mcdbrendan
haha. wheres octane guy, heather, kenchan, anyone??? so much for dedication...
Old Jan 10, 2007 | 03:39 PM
S Curvz's Avatar
S Curvz
Check out this thread
https://www.northamericanmotoring.co...washing+towels
Richard talks about it there.
Also, make sure you clean the pad WHILE polishing. Get Octaneguy, Richards, DVD. Its very good.
Old Jan 10, 2007 | 04:57 PM
kenchan's Avatar
kenchan
i use warm water and soap. no tricks really.
Old Jan 10, 2007 | 05:06 PM
mcdbrendan's Avatar
mcdbrendan
DVD is on the way (should be here monday??? are there deliveries on MLK day?)
Old Jan 10, 2007 | 05:08 PM
mcdbrendan's Avatar
mcdbrendan
Sounds good!
Old Jan 10, 2007 | 07:36 PM
MiniMaybee's Avatar
MiniMaybee
After using a pad I will clean it with warm water and Dawn. For Epic pads I have started using vinegar warm water and Dawn (I have also been adding vinegar to my microfiber wash water on occasions). Cleans them up real good.
While polishing I have a stiff brush like for fabric. I use it to periodically remove the crusties that form on the outer radius. It needs to be stiff, but not so much that it damages your pad. The black pad is softest and therefore most susceptible to damage so if your cleaning brush won't hurt the black pad you're good to go.
Old Jan 10, 2007 | 10:57 PM
SHRTSTAK's Avatar
SHRTSTAK
Sink full of warm water, half a cup of laundry detergent. Let them soak for like 10 minutes. Agitate the pads a little. Drain the water and rinse off with cool water.
Depending on how dirty the pads are you may have to wash, rinse, wash, rinse.
Have fun.
Old Jan 11, 2007 | 12:14 PM
jwardell's Avatar
jwardell
I first handwash them, with a little dish soap and plenty of working and squeezing. Then I throw them in the washing mashine with all my towels/MF and wash with Der Wunder Wasche
Old Jan 11, 2007 | 01:52 PM
Prima Car Care's Avatar
Prima Car Care
That is very similar to how we wash pads too... some warm water and Dawn.
  1. Fill sink (or bucket) with soapy (Dawn), warm water
  2. Let pads soad for 10-15 minutes
  3. Work work in the soapy water with your thumbs
  4. Rinse with warm water
  5. Air dry (often it takes several hours to a couple of days to dry)
Water-based polishes (like Prima) will wash right out, even if they been sitting for a long time before washing. For these, you can usually just wash them with some Dawn and warm water and don't have to let them soak.
Oil-based polishes can be a little more stubborn, but still wash out without too many problems, especially when soaked.
Synthetic waxes, like Epic, should be washed immediately after use to prevent them from curing in the pad. I advise to wash synthetic wax out of a pad within 10 minutes after you're done using the pad. This usually works out to be pretty convenient since most synthetics require some wait time before buffing off anyway.
Also, vinegar or rubbing alcohol can both be very helpful in removing stubborn oil-based polishes or synthetic waxes from your pads.
-Heather
Old Jan 11, 2007 | 02:02 PM
agranger's Avatar
agranger
I'll 'ditto' that process. I use the Sonus polishes and, after a longer polishing session there will be a fair amout of polish stored in the pad. I start by just squeezing a bit of dawn directly on the pad and working it well with my fingers to squeeze out the excess polish and rinse with warm water to remove the bulk of it. Then I work steps 1 through 5, above.
Pad storage is also important to me, as my garage is old and dusty. I keep 'em in gallon size zip-loc bags, stored OPEN and open-side-down until they have had several weeks to dry out
Old Jan 11, 2007 | 02:16 PM
Prima Car Care
Yes, that is a great idea! You don't want dust/dirt settling on them while the dry. Ditto that!
-Heather
Old Jan 11, 2007 | 02:29 PM
kenchan's Avatar
kenchan
old pict, but i use these tubs... like $3 or something at target each.
Old Jan 11, 2007 | 04:27 PM
mcdbrendan's Avatar
mcdbrendan
that rolling toool tray is AWESOME! where did you get that? and how much was it (please say under $50)
Old Jan 11, 2007 | 04:53 PM
mcdbrendan's Avatar
mcdbrendan
ahhh crap. its the griots cart, and wayyyyyyyy out of my proce range. looks like im sticking to milk crates...
Old Jan 11, 2007 | 05:37 PM
kenchan's Avatar
kenchan
thanks. yah, it's a bit pricy but it's really nice.
Old Jan 11, 2007 | 06:05 PM
agranger's Avatar
agranger
-Heather
I used to store my pads in the open, on a shelf in my garage. When I first got involved with my local club (www.metroplexmini.org), a member came over for some quick polishing work... an installer had botched a clear bra install and used a dirty t-shirt to try and rub out the bubbles... turning the brand-new jet black paint to a scratchy dark grey when you looked at it in the light. I started polishing and immediately noticed a scratch (deeper than the ones I was supposed to be removing) that looked like it had been made by an etch-a-sketch... right down the middle of the bonnet! A fleck of dirt must have fallen on the pad and the owner suddenly got very nervous. The scratch came out (once I switched to a fresh, clean pad, and spent a few minutes working on it), but I've been much more careful with my pads since then...
Old Jan 11, 2007 | 06:30 PM
mcdbrendan's Avatar
mcdbrendan
Good advice. I will definatly be spending some time in Wal-Mart getting a cart and come things to hold my pads.
Old Jan 11, 2007 | 08:20 PM
kenchan's Avatar
kenchan
if you ever go to the Container Store get some round jars with
sealable twist top. the smaller ones will fit the Griot's dressing applicator
(the blue round one) perfectly. i got a couple of those for my
blue pads, and also for my Q-Tips and for some misc applicator pads.
patsum
26
May 29, 2021 06:29 PM
molala
Oct 2, 2015 01:53 PM
sempaipaul
Sep 18, 2015 03:05 PM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 4, 2015 09:23 AM
