front wheels harder to clean than rear
Old Jan 8, 2007 | 11:08 AM
luluzapcat's Avatar
luluzapcat
while the rear wheels come clean with a few swipes & little scrubbing, i find i can't get the black grit (brake dust?) off the front wheels even with wheel brush & real effort. why is this? what can i do about it? tried a citrus cleanser to no avail.
also (i should know better than to ask), do you all clean back around to the inside of your wheels, on the unfinished, semi-hidden surfaces?
thanks, detail pros-
diana
Old Jan 8, 2007 | 11:13 AM
MLPearson79's Avatar
MLPearson79
The fronts are much harder than the rears. They get a lot more brake dust. You might need to get a wheel-specific cleaner, let it sit for a few minutes on the wheels, and then brush them down and rinse. Then you want to wax all 4 wheels with a synthetic wax - from then on, the dust should practically melt off with water (maybe a little mild wash - I just use a microfiber mit with my car wash soap water to get it off and it comes right off). If you keep them waxed it's a lot easier to get off.
Old Jan 8, 2007 | 11:24 AM
kenchan's Avatar
kenchan
front brakes work harder than the rear to stop the car straight.
try Prima WheelShield. it has a mild abrasive polish and protects
with its high temp wax in a one-step process.
or do it in 2 steps. step1 = ScratchX, step2 = your favorite wax.
i use to use CleanerWax by meg on stubborn wheels, but i think it
separated inside or rotted or something. im going to toss that
this week.
Old Jan 8, 2007 | 01:20 PM
luluzapcat's Avatar
luluzapcat
thanks, folks--
leadingme to one more question: will any of my zaino lineup act as "synthetic wax" on the wheels (z2, z6)? or do i need a different product?
Old Jan 8, 2007 | 01:44 PM
S Curvz's Avatar
S Curvz
this week.
SratchX on wheels? Just get wheels without scratchs Good Idea though.
Old Jan 8, 2007 | 04:44 PM
kenchan's Avatar
kenchan
yah, basically you're polishing out the grime from the top surface
of the clear. so similar to removing tar/oils that have stained your paint
and removing a very slight coat of the clear while removing the grime.
Old Jan 8, 2007 | 04:49 PM
S Curvz's Avatar
S Curvz
Ahh, I just clay I got some new wheels, as soon as I can get them clean, im going to put wheel sheild on.
Old Jan 8, 2007 | 05:31 PM
El_Jefe's Avatar
El_Jefe
yeah either that brand that has the naked girl on it or detailers stuff. You need a temperature rated wax for that.
So far, the best for me, a weekly detailer, is speedshine by griot's. It cleans off the wheels AFTER I scrub them with griot's wheel cleaner. Wheel specific cleaner is really key to washing off brake dust. I experimented on wheels that have not been cleaned in a year. 90% clean in one try of the wheel cleaner and a boars bristle brush. quick detailer adds a nice slick coat to the wheel if you do it 1-2x a week. takes about 1-2 mins between washes to make them sparkle. octaneguy showed me that.
Old Jan 8, 2007 | 06:20 PM
MLPearson79
Claying would work probably as well as Scratch-X...although I don't know if one would be any less labor-intensive than the other.
As far as wax options go...I got a bottle of Wheel Shield in my massive Christmas box with the PC, but I haven't used it yet since the Epic is holding up so well. Once a week or so I give them a little spray with Slick, wipe them down with a regular blue MF, and they're like new (aside from the little bit of curb rash I got last week...grr).
Old Jan 8, 2007 | 06:31 PM
lotsie's Avatar
lotsie
If you need to get real bad stuff off, simple green works.
Then clay and synthetic wax them.
Simple green did this.
Mark
Old Jan 10, 2007 | 05:08 PM
luluzapcat's Avatar
luluzapcat
oh, i like the simple green idea for the "green" part. if i can do that w/o wearing myself out scrubbing, that's my route. we'll see next weekend...thanks all!
Old Jan 10, 2007 | 08:11 PM
kenchan's Avatar
kenchan
dang, lotsie, that is clean! wow.
i just used my Griot's CarWash at about 2x the normal concentration
when i washed my SSR wheel's back side over the weekend. did pretty
well. i didn't want to risk getting any strange spots or something on
the front side. it's got a lot of crevises as it's a multi-piece wheel and
takes some effort to dry... although i used my shopvac to blow it dry
for the most part.
Old Jan 10, 2007 | 08:16 PM
mini552's Avatar
mini552
All good suggestions as to cleaning/waxing wheels, but I couldn't take it any more - had Scott @ Central Coast Coopers swap out the factory soot-generation units (aka factory brake pads) for Hawk ceramic pads - better braking, no squealing, minimal brake dust.
Old Jan 10, 2007 | 08:24 PM
kenchan's Avatar
kenchan
^^ i'd do the same if it was a daily driven car. my R90's when i was
using my MCS as a commuter at one time was black by the 3rd day.
JPMontes3
Aug 23, 2015 01:26 AM
Minibeagle
Aug 13, 2015 10:00 AM
xraycat
Aug 12, 2015 02:36 PM
