Releasing pulley tensioner without tool
Old Dec 28, 2006 | 06:52 AM
Aeromax's Avatar
Aeromax
Is there an easy way to do this without the special tool? I'm out of town doing an sort-of emergency repair on my car at my parent's house, and I need to get this done without the special tool.
Old Dec 28, 2006 | 09:27 AM
daflake's Avatar
daflake
Not that I know of.
Old Dec 28, 2006 | 11:49 AM
minibeel's Avatar
minibeel
Coordinator :: PDX MINI
If you are refering to the tensioner on the serpentine belt which wraps around the supercharger pulley...
I used a crow bar as a lever and some random item (I forget now) wedged in a "safe" place in/around the block as a pivot. It is not easy and you can damage the belt as well as other parts. I was replacing my belt anyway... Once the tensioner is moved, you can put a screwdriver (or similar item) in the hole on top to hold it.
Think "lever" and "safety" and go to it!
dan
Old Jan 1, 2007 | 08:59 AM
daleCarlsbad's Avatar
daleCarlsbad
From Herbie Hind
put a 16mm socket on the large front pivot bolt. then use a large pry bar against a 6mm pin inserted in one of the small holes in thetensioner side near spring. pry on bar and insert a drift or leather awl or small screw driver (you get the idea) into the lower hole of the spring steel that comes up as it presents itself. this will hold the tensioner while youwap the belt.
BernieCoop
Sep 10, 2021 03:15 AM
patsum
26
May 29, 2021 06:29 PM
Sep 4, 2015 03:56 PM
Sep 3, 2015 02:06 PM
M7Speed
Sep 3, 2015 07:48 AM
