how can I get road tar off my wheels?
Old Dec 10, 2006 | 04:14 PM
Fidge's Avatar
Fidge
Hi,
It's been a while since I have posted anything, but I check back once in a while. I have a ton of road tar on my v-spokes and regular car washing doesn't remove. I was thinking of using wd40, any other suggestions are appreciated, Thanks
Old Dec 10, 2006 | 04:15 PM
boolean_bones's Avatar
boolean_bones
NAPA bug and tar remover has always worked for me.
Old Dec 10, 2006 | 04:19 PM
2Miniacs's Avatar
2Miniacs
WD-40 works great. Shouldn't take more than a couple minutes. I recommend reapplying wax to areas that you've used the WD-40 on though.
Old Dec 10, 2006 | 04:22 PM
Fidge's Avatar
Fidge
I have never waxed the wheels. Is it necessary to wax them after using wd40?
Old Dec 10, 2006 | 04:25 PM
2Miniacs's Avatar
2Miniacs
Nope, not the wheels.....sorry.....didn't read the thread well enough. Rewaxing would only apply to the paint on the car. Some folks wax their wheels but I'm of the opinion it's not required.
Old Dec 10, 2006 | 04:27 PM
nixjosh2's Avatar
nixjosh2
^+1 Wd40
Old Dec 10, 2006 | 04:29 PM
Fidge's Avatar
Fidge
Thanks for the info, I think I'll give the wd40 a try
Old Dec 10, 2006 | 06:42 PM
kenchan's Avatar
kenchan
if that doesn't work use gasoline on a rag.
make sure you dispose your rag properly in a tin container.
Old Dec 10, 2006 | 06:50 PM
GoodFinder's Avatar
GoodFinder
For painted surfaces I use Turtle Wax Bug & Tar Remover.
Old Dec 10, 2006 | 08:21 PM
MiniMaybee's Avatar
MiniMaybee
If your wheels had been waxed, it would have been a lot easier to get the tar off - like finger nail easy.
I know WD-40 works as does Goof-Off. No need to get the gasoline out to tackle tar when there are other, safer products available.
Old Dec 10, 2006 | 08:47 PM
mitchman's Avatar
mitchman
If they are really bad, you might try using a plastic putty knife to really get after it. The hood on my sister inlaw's Durango was so bad I needed to use a plastic putty knife to get the baked on sap off. I was a little hesitant at first, but it came out great!
TJANK
Aug 24, 2015 06:11 PM
BowserKart
Tires, Wheels, & Brakes
Aug 20, 2015 01:24 PM
nomar116
Aug 9, 2015 09:42 AM
