Replica R90s
Old Dec 9, 2006 | 11:39 AM
in the flesh's Avatar
in the flesh
Replica R90s
http://cgi.ebay.com/ebaymotors/17-17...spagenameZWDVW
Does anyone know more about these? How much do they weigh? And are they legit? Im seriously considering them..
Thanks!
Old Dec 9, 2006 | 11:54 AM
Jtrem's Avatar
Jtrem
I saw them awhile back to me they aren't the same thing. If you compare them side to side real R-90's have a different color to them.
Old Dec 9, 2006 | 12:20 PM
AKIndiMini's Avatar
AKIndiMini
For that price, I'd rather find a good used set of the "real" ones. I just don't really trust no-name brand wheels...
Old Dec 9, 2006 | 01:31 PM
tomm9050's Avatar
tomm9050
I have some 17 S-Lites you can have with RFs / 3000miles
700.
Old Dec 9, 2006 | 01:32 PM
tomm9050's Avatar
tomm9050
I have some 17 S-Lites you can have, with RFs / 3000miles
700.
Old Dec 9, 2006 | 04:02 PM
Tit's Avatar
Tit
I think they actually look better than the stock R90's because the lip is a bit deeper and more polished, they are lighter and the offset is also 40, so they sit out a little more. Several Aussies are running them....
Old Dec 9, 2006 | 05:01 PM
Jtrem's Avatar
Jtrem
They do look pretty good, but for the price they want I would go with something else.
Old Dec 10, 2006 | 08:17 PM
in the flesh
Yeah except thats exactly the look I'm looking for, and where did you get those center caps, I havent seen those before
Old Dec 10, 2006 | 08:45 PM
Jtrem's Avatar
Jtrem
you can buy the centercaps from the dealer for pretty cheap.
Old Dec 10, 2006 | 08:49 PM
in the flesh
the ones with the actual logo on it with the wings? I like those ones a lot
Old Dec 10, 2006 | 08:54 PM
mini_jenny's Avatar
mini_jenny
What else would you recommend at $130/wheel in 17X7?
Old Dec 10, 2006 | 11:53 PM
Tit's Avatar
Tit
yeah..dunno what they cost up there, but they were bloody cheap down here! Those centre caps came with the wheels as far as I understand...I'll get the owner on here to answer some q's...
Old Dec 11, 2006 | 12:38 AM
minigolf's Avatar
minigolf
That'd be me, so if you do have any questions let me know.
That's probably fair enough. However, the wheels do supposedly have full European TUV certification which in theory means their quality is first rate. I've been running mine for over 40,000kms (25,000 miles) or a bit over 2 1/2 years now. I've certainly had no problems. I've taken them on some pretty spirited drives on bumpy roads and also on the track.
The R90 replicas are made by an Italian company call Ruotecompany they also make replice wheels for Audi/VW and BMW. Chances are you've probably seen some of these statesaide already, you just didn't know it.
The replicas weigh about 2kg (4.4lbs) per wheel less than the OEM R90s which seems to be a big deal for most guys in the states. They are, of course, only a one piece design however.
As for cost, you're having a laugh if you reckon these are expensive. Mind, we're probably getting ripped off for the OEM gear. In Aussie dollars the OEM R90s with runflat rubber can cost over AU$5000 (US$3900), whereas the R90 replicas, with far superior rubber to the runflats can be purchased for comfortably less than half that price. For example, I paid a touch over AU$2100 for mine with some really fine Goodyear rubber included. So to be able to get these for AU$670 (US$1650) is a bloody bargain as far as I'm concerned!
The centrecaps with the winged logo come with the wheels. If you wanted to use the OEM "MINI" caps you'll need to get the dremel out as they are too bug by just enough to be a right PITA.
As noted by Tit, these do have a different offset to the OEM wheels and they sit out closer to the guards, which IMO looks a bit nicer. Be warned though, that if you are on lowering springs you may get rubbing on some tyres. I'd steer well clear of 215s for example. The 205/45s on the pics above rubbed ever so slightly, but the 205/45s I have now, with a slightly rounder sidewall, don't rub at all unless on a very steep hill climb or with a couple of people in the back. Mind, with either tyre the rubbing is so minimal I have never been greatly concerned by it.
The only negative thing I have heard about these wheels is from people running them on salted roads in the UK. In some instances the studs around the outside, which are glued into place, have corroded. With our warmer climate and certainly no need to salt our roads, this has not been a problem in Australia to the best of my knowledge.
That should cover most things, but if you want to know more just let me know.
Cheers Liam
Old Dec 14, 2006 | 08:47 PM
95Viper's Avatar
95Viper
Are these labeled on the rear of wheel diffferently than OEM?
rrglo
Sep 22, 2015 10:05 PM
mobygjc
Tires, Wheels, & Brakes
27
Sep 8, 2003 06:02 AM
