Tire pressure- how cold is cold?
Old Dec 1, 2006 | 07:47 AM
NMgokart's Avatar
NMgokart
Just checked my pressures, reading 30 all around. This is with ambient temp at ~28F, and after sitting 1.5 hrs post-commute.
Would the low ambient temp cause them to read lower?
The tire label specifies certain max pressures cold, but what is cold?
Old Dec 1, 2006 | 07:55 AM
goaljnky's Avatar
goaljnky
Your tire pressure will go up, or down 1 psi for every 10F ambient change. That being said, you should check and change your tire pressure as the weather changes. Keeping in mind that the pressure will go up 3-4 psi as the tires warm up while driving. Depending on your driving style, of course.
Old Dec 1, 2006 | 11:45 AM
kenchan's Avatar
kenchan
i check my tires early morning or late evening giving 4-5hrs cool down time
before i measure. if your car's parked outdoors measure it when the
sun is not out as direct sunlight can alter the tire pressure by 2-3psi
on one side of the car.
i like to run 33psi on my civic and legacy up to +3/-2 psi.
they recommend 30 and 31 psi cold, but i know they go for comfort
more than performance so i use the higher end.
on my MCS which is garaged during the week i check tire pressure
Friday night so that im ready to go on Sat morning. i usually run
about 34 +1/-0 psi. unfortunately due to snow, my MCS will not
be driven for some time...
Old Dec 1, 2006 | 08:40 PM
AlpinaM3's Avatar
AlpinaM3
Since you really dont know what the temps are inside the tire are, stone cold in the morning would be the most consistant.
W0TM8
Dec 19, 2019 07:50 AM
khumpert
Nov 30, 2015 11:48 AM
minicoclub
Aug 25, 2015 09:07 AM
minipopkart
Aug 13, 2015 05:22 AM
