Drivetrain 2% crank pulley? I know what your thinking!
Old Nov 28, 2006 | 06:46 PM
Longboard Mini's Avatar
Longboard Mini
I know that this was talked about allot but I read today in another thread that engines "might" be failing do to lightened crank pulleys.
Has this happened to you???
I'm planning on putting on a 2% but now I just want to make sure it's safe.
Any personnel experience would be greatly appreciated.
Longboard
Old Nov 28, 2006 | 08:28 PM
Longboard Mini
Hello Hello Hello. Anyone.
Old Nov 28, 2006 | 11:03 PM
CooperSS's Avatar
CooperSS
M7 16% + M7 2% 10,000 miles, many track days and no problems.
Bill
Old Nov 28, 2006 | 11:20 PM
ca$per's Avatar
ca$per
I just added my M7 2% CP and would do it all over again anytime . You will read that it harms the engine, but till date I saw no real life complaints from NAMers. The engine feels more lively and I don't honestly believe that the team at M7 will sell you a part that will harm your engine. Go For It
Old Nov 28, 2006 | 11:39 PM
not-so-rednwhitecooper
19+3, 10k miles.
no issues.
Old Nov 28, 2006 | 11:48 PM
MarioKart's Avatar
MarioKart
Vendor
Originally Posted by not-so-rednwhitecooper
19+3, 10k miles.
no issues.
How much boost you running with this cold weather? I'm betting about 18psi with H2O sprayer and 17% only.
Mario
Old Nov 28, 2006 | 11:56 PM
Mario
Didnt we go over this in another thread?
19-21 psi
Old Nov 28, 2006 | 11:58 PM
Bster's Avatar
Bster
I'm thinking "DO IT!" It's good stuff!
Old Nov 29, 2006 | 12:05 AM
MarioKart's Avatar
MarioKart
Vendor
19-21 psi
Sorry bro, also the Detrot ByPass Valve is awesome. You have it right? Once again I forgot. BTW have you dyno'd your Mini?
Old Nov 29, 2006 | 05:47 AM
markldriskill's Avatar
markldriskill
There was a thread like this around a year ago, but it asked people to specify their SC and crank pulley sizes, and how long each had been running, for the express purpose of trying to determine whether crank and/or SC pulleys might significantly increase the risk of failure. I would say that the data was not damning of either type of pulley, even though it was probably not statistically sound due to too small a sample.
Some proponents of engine dampening might disagree, as I believe there was one failure experienced out of the roughly 20 or so persons who provided data points. I remember at the time it did not settle the argument.
What I have seen complained of most in this forum is "shredded" belts. No one has argued that the 19% SC pulley is easy on belts, due to the smaller radius turn. Also, from what I've read here, it is arguable that the belt should be checked regularly no matter what pulleys you are running.
Old Nov 29, 2006 | 07:09 AM
jymontoya's Avatar
jymontoya
19+3, 10k miles.
no issues.
Do you have to splice in some sort of FCD to keep the SES light from coming on??
Old Nov 29, 2006 | 07:40 AM
ScottinBend's Avatar
ScottinBend
Not to start another war......but we won't know if a non-dampened pulley will harm the MINI until we start seeing people with 50,000 miles on the engine. The short term effect is probably nill, but who knows what the long term one is. There is data from different engine manufacturers that will confirm or deny that any damage will occur. I trust the MINI engineers to determine what is a safe design for the long term.
Old Nov 29, 2006 | 01:15 PM
No bypass, just a bock off plate.
every time i trip overbost, i just start the car 5 times and it goes away.
Old Nov 29, 2006 | 01:40 PM
THE STIG's Avatar
THE STIG
Longboard
just fitted one to my GP it goes a lot better, and i fitted cold plugs just to be safe, then i fitted a GTT works replacment air fillter. i am thinking of fitting a v2 alta intercooler in the next few weeks. then a re map mth. if you fit it yourself you will need a puller. and you need to use a extra strong bearing seat locktight, green or blue. good luck
Old Nov 29, 2006 | 02:58 PM
RedSkunk's Avatar
RedSkunk
Agreed. But as far as MINI engineers go.. Ah, who knows with that lot.
I will wait for long-term results before doing the crank pulley however..
Old Nov 29, 2006 | 03:02 PM
Man, what a bunch of pansys.
Just put the damn pulley on and hope a rod doesnt come thru the block!
hehe...
Old Nov 29, 2006 | 09:04 PM
Longboard Mini
Thanks for the help guys.
I would love to hear from someone who has 50K with a lightened crank pulley but I don't know if I will. I plan on keeping my car for years. I love everything about my car and plan some day putting a new engine in it. I just would rather not do it at 75K.
I have a 15% SC pulley and was thinking of going with a 3% crank pulley. I like the idea of an 18% total combo rather then a 19% SC pulley. I'm looking at building as much torque as possible. My car is a street car. I'm looking to add more torque lower in the rev range. To me torque rules over hp.
I might add a Head but one that gives torque. Come January I'm back on the mod train with 3K to play with. Figuring out what to do is driving me crazy.
Longboard
Old Nov 29, 2006 | 09:10 PM
MarioKart's Avatar
MarioKart
Vendor
I did a 2% today, total of 19% and I love it. Another great mod.
Old Nov 29, 2006 | 09:33 PM
Longboard Mini
Do you work or just mod your. Your on fire man
Did you do the pulley yourself?
Longboard
Old Nov 29, 2006 | 11:03 PM
MarioKart's Avatar
MarioKart
Vendor
Longboard
no I had it done and Steve's Clinic in Northridge, CA. Took about an hour. It was only $65 to install.
Old Nov 30, 2006 | 07:02 AM
jymontoya's Avatar
jymontoya
VERY SWEET to know. I was looking at doing this at home, but it seems inaccessible without lifting the engine all the way out...
Need to revisit with removed fender liner.
ebowling
90
Aug 4, 2019 09:15 AM
Toolman
Jan 20, 2016 06:50 AM
mackedmini
Aug 20, 2015 02:35 AM
keck.j
Aug 18, 2015 08:18 PM
Lt. Dan
Aug 10, 2015 12:46 PM
