R50/53 hey
Old Nov 15, 2006 | 09:51 AM
piff2121's Avatar
piff2121
hey
Hi m about to get a 2003 mini s with 47k it is about to run out of warranty im going to buy it but i am concerned if i should get the extended warranty? is there an extended warranty from mini? im concerned becouse ive read a couple post about bad trannys and i dont want that to happen to me....is the mini expense to maintain?
Old Nov 15, 2006 | 10:29 AM
kenchan's Avatar
kenchan
47k miles? should already be out of warranty... no?
if you intend to keep it for a while i recommend you get the MINI
ext. warranty. talk to your SA about it.
tranny problem? not on mine.
Old Nov 15, 2006 | 10:40 AM
ProfessorDave's Avatar
ProfessorDave
Ken, piff has 3,000 left (48 mos, 50,000k).
I'd schedule an appt. with a dealer to have to looked over for any repairs. Have the ECU scanned for any codes that may have been thrown (for example, I've had an oil pressure sensor go and the SES light only came on briefly then disappeared).
I believe there is a service bulletin about a rattling neutral relay in the trans (sounds like gravel rattling around the trans in cold weather).
The other stuff that tends to go wrong would be obvious, such as rusting rocker panels, window motors, door locks, etc.
Enjoy your MINI!
Old Nov 15, 2006 | 11:26 AM
piff2121's Avatar
piff2121
thanks
Im not buying it from mini dealer..so am i eligible for extended warranty from mini? the dealer said they offer extended warranty but i like to go with mini.
when i go to appointment what will they charge me? and if the car needs work how much or what % will i pay since free maintence is only untiil 36k?
Old Nov 15, 2006 | 11:29 AM
kenchan's Avatar
kenchan
ProfessorDave and DropoutKen
scratch my bad info then... oh well.
Old Nov 15, 2006 | 11:42 AM
ProfessorDave
You'll pay nothing for any repairs since you are under warranty. If you have any scheduled maintenance done (such as an oil change) you'll pay for that.
I can't help you with the extended warranty issue, but there has been some discussion on that topic in the past.
Old Nov 15, 2006 | 12:48 PM
piff2121's Avatar
piff2121
thank
thanks on your help. professor!
IrishMCS
Dec 1, 2015 04:21 PM
Oilfieldtrash
Sep 21, 2015 09:59 AM
ZeroGravity
Sep 15, 2015 06:43 PM
Timmy_r53
Sep 14, 2015 01:59 PM
MiniUnz
Sep 14, 2015 11:11 AM
