painting chips AFTER Zaino'ing
Old Nov 1, 2006 | 04:07 AM
umberto's Avatar
umberto
yesterday I put on one coat of Z 5 and then 2 coats Z 2 on my chili red. I noticed while I was buffing off the first coat that there were a few very little chips on the bonnet, with the white primer visible, but since there was already that one coat of zaino on, I decided to finish the process and applied the other 2 coats of Zaino. The chips are not visible unless your eyes are a foot from the car, so painting them would be for protection to avoid rust, not for appearance sake.
question 1) will zaino seal out moisture so these little chips will not rust, or at least let me wait until springtime to attend to them?
question 2) to apply paint to the chip, do I need to remove the Zaino in the chip or can I apply the little drop of paint on top of the zaino? how? I'm thinking that since zaino has no silicone then a dot of paint on zaino would be OK
Note: the chips are small, meaning that to hit the chips with paint, I am planning to apply the paint with a point of a toothpick
Old Nov 1, 2006 | 07:14 AM
kenchan's Avatar
kenchan
it's up to you... you can leave it as is and some oxidation will show up
in the dot, but probably won't do much anything else. but if you're ****...
1. if you're in an area where road salt is used, don't wait. fix the chip.
2. you will need to remove all wax before applying touchup... otherwise the
bond is weak.
Old Nov 1, 2006 | 07:16 AM
lotsie's Avatar
lotsie
I would remove the zaino from the area. You want the paint on the car, not the zaino. You can layer back on the zaino to the area after you are done painting.
Mark
Old Nov 1, 2006 | 09:27 AM
jwardell's Avatar
jwardell
You can easily spot-remove the wax with some dish soap. Rinse, dry, touch up. Allow to cure for a few days, then re-apply the zaino to the spot. I just did the same last week.
Unless the chip is large or deep, it probably won't rust. Body metal isn't rust-prone like it used to be. Otherwise they wouldn't be able to afford your 12-year rust warranty!
Old Nov 1, 2006 | 09:35 AM
kenchan's Avatar
kenchan
if it goes down to the metal it seems to rust as it will turn orange.
they are treated at the plant before painting though but if it goes
through, it's just metal.
Old Nov 1, 2006 | 03:31 PM
Prima Car Care's Avatar
Prima Car Care
Mark
Ditto!
-Heather
Old Nov 1, 2006 | 03:38 PM
too cool blue!'s Avatar
too cool blue!
Sal told me to use alcohol to remove Zaino.
Old Nov 2, 2006 | 10:47 AM
jwardell's Avatar
jwardell
Alcohol will work too
jeri534
Nov 6, 2015 01:40 PM
penguinplf
Oct 11, 2015 07:36 PM
M7Speed
Oct 1, 2015 07:05 AM
tcjake
Sep 30, 2015 08:14 AM
Nicefeet
Sep 27, 2015 11:14 AM
