Squeaky wheels?
Old Oct 28, 2006 | 09:14 AM
grimmrimmer's Avatar
grimmrimmer
Squeaky wheels?
I have a stock MC (Auto) that apparently doesn't like moving slowly.
Whenever I am moving slowly (around 0-10 MPH), I hear a low pitch squeal/whine coming from my wheels (not too sure which one). The noise relates to that of a squeaky door hinge (i.e. one that's lacking grease).
Do you think that it's a similar situation here? It sounds like there just isn't enough grease where at least one of the wheels connect to the car. I should also note that this has nothing to do with braking the car.
The car is relatively young (9k miles). Is this a problem that my warranty would cover? If so, then I'd probably just do that to be on the safe side.
Thanks,
Chuck
Old Oct 28, 2006 | 09:17 AM
HomerJ's Avatar
HomerJ
Bring it to the dealer. It should be covered under warranty.
Old Oct 28, 2006 | 10:07 AM
Crashton's Avatar
Crashton
More likely it's a noise caused by one of your brakes than noise from your wheels. Could be as simple as a bit or rust of a tiny stone stuck in your brakes. If you are under warranty definitely take it into the dealer. Post back & let us know what it is.
barnoun
Sep 17, 2018 05:04 PM
khumpert
Nov 30, 2015 11:48 AM
SosoMINI
Nov 22, 2015 03:17 PM
Tires, Wheels & Brakes
Aug 26, 2015 11:02 AM
BowserKart
Tires, Wheels, & Brakes
Aug 20, 2015 01:24 PM
