Defi Blue Racer gauges are here!
Old Oct 20, 2006 | 03:53 PM
StoopidGirl's Avatar
StoopidGirl
Yes my dear MINI friends, you heard me right! I have the highly saught after, just released to the USA, Defi Blue Racer Gauges!
Now you can be one of the first to have these amazingly atractive gauges!
For a limited time I will be offering some unbelievably low introductory prices.
Please PM or email me for quotes; info@rogueminis.com
Not only are these gauges the best on the market they look dashingly sexy (get it? DASHingly...oh I'm queen of the bad jokes) and are sure to compliment your MINIs unique styling (and make me jealous because I want them too!). Take your tuning to the next level!
-Exclusive gauges for USA which are derived from quick-responsive and high-accurate Defi analog gauges.
-Boost, pressure, temperature, exhaust temperature, and volt gauges are available. The diameter is 2 1/16inches(52mm).
-Blue illumination using high-brightness LEDs
-Lightning-like Opening / Closing mode see the movie
-Self-diagnostics function monitors both sensor disconnection and short-circuiting during
startup.
a) Sensor disconnection check
This function reports any in-proper connections, broken or disconnected sensor or
sensor wire. The pointer will wave between 250 and 260 degrees.
b) Short-circuiting check
This function indicates any short circuit on the sensor or sensor wire.
The pointer will wave between 10 and 20 degrees.
-Full 270 degrees sweep dial provides ultimate visibility.
-A mounting bracket and instrument case is provided with the product.
-The red triangle of the regular position bezel can be used as a warning indicator and others.
-Does not require the Defi-Link Control Unit for use.
Blue Racer Gauge cannot be connected to the Defi-Link System.
please do not hessitate to contact me with any questions...I'm nice I promise
Filmy
15
Jun 6, 2023 06:27 AM
dinomaniac
Sep 18, 2018 04:19 AM
xSpartanCx
Dec 9, 2015 08:35 AM
ryGuyMCS
Oct 6, 2015 12:04 PM
molala
Oct 2, 2015 01:53 PM
