Suspension My MINI -> in your hands
Old Oct 16, 2006 | 01:41 PM
RedSkunk's Avatar
RedSkunk
There are threads like this, but considering that I have my own speshual needs, I thought I'd just create a new one. All responses appreciated.
It's an '06 MCS.... Tire / wheel combos are being explored, my specific questions here are purely suspension. The MINI is my daily driver. I autocross it, a lot. But it's purely for fun, I'm not concerned about classing. I want a good autox car that's still really driveable on the street. Budget is def. limited.
I've already bought the 22mm alta rear swaybar, but are going to put off installing it till spring. And while I'm in there, I might as well do anything else that's related.
I'm seriously considering springs, and this is mostly cosmetic (the 1" drop). Undecided at the moment. Camber plates are on my radar. So I'm thinking, budget allowing, to do the swaybar, springs, and camber plates all in one go. What am I missing here, what's needed? I want the most bang for my buck.
Old Oct 16, 2006 | 02:11 PM
BSUCardinalfan's Avatar
BSUCardinalfan
I think you've got it. I just did the rear swaybar and H sport springs on my '03, and it made for a great autocross car (STX) once I added the 17x7.5" wheels and sticky tires.
Do you have the LSD? Other than that, make sure to get an alignment after you get the suspension changed, and you'll be good to go.
Old Oct 16, 2006 | 02:20 PM
RedSkunk's Avatar
RedSkunk
Have LSD, and yes, want to do a good alignment for autox once I'm at a good initial set-up.
Old Oct 16, 2006 | 02:36 PM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
If you do springs and front camber plates, you really need to have rear adjustable control arms.
https://www.northamericanmotoring.co...ad.php?t=81381
Your car needs less negative camber in the rear then the front to help it rotate. Most auto-x # are @ -2.2 front, -1.5 rear.
Lowering springs affect the rear more than the front giving the rear like -2.0. You would then have to adjust the front to -2.5 or so to have the rear come around. That would increase tire wear.
Also I know the 05and 06 have some rear camber adjustment, but I don't think it's very much.
Hope that makes sense.
Old Oct 17, 2006 | 05:35 AM
Veni_Vidi_Vici's Avatar
Veni_Vidi_Vici
I'd advise against the H-Sport springs, at least for the front. The fronts are actually softer than stock. This causes more nose-diving and bouncing off of the stops and 3-wheeling. I actually changed the fronts to H&R. Much nicer on the autocross course but choppier on holey Western PA roads.
Old Oct 17, 2006 | 06:12 AM
etalj's Avatar
etalj
that's interesting. Randy Webb's favourite choice out of all the springs are the H-Sports
Old Oct 17, 2006 | 06:05 PM
Veni_Vidi_Vici
The H-Sports just didn't work as well with my setup and driving style. YMMV
Getrieben
Sep 12, 2024 07:03 AM
The_Kid
Cincinnati MINI Club
Aug 4, 2016 02:40 PM
1964geo
Aug 10, 2015 06:22 AM
Dashdog
Aug 10, 2015 06:17 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
