Wheel Tool
Old Oct 7, 2006 | 08:51 AM
MiniSuperCooper's Avatar
MiniSuperCooper
Wheel Tool
I was going to wax my wheels this weekend, but I can't find the tool to remove the hub caps with...(are they called hub caps? not sure what else to call them) I checked the bag in the boot. Am I missing something? Or am I suppose to use something else?
Old Oct 7, 2006 | 09:49 AM
rhawth99's Avatar
rhawth99
If you have an MCS, the tool is in a rectangular styrofoam like container in the boot next to the battery. The battery is under the carpeting in the boot.
Old Oct 7, 2006 | 11:15 AM
TooTall's Avatar
TooTall
Yeah, I had to spend some time looking for it too, I think the MA's should show you how to change a tire when you pick the car up.
Mine was a black U-shaped piece of round steel rod.
Old Oct 8, 2006 | 02:11 PM
MiniSuperCooper
Found it! Thank you...it's very well hidden. That styrofoam thing looks like it's there for packing purposes, but surprise, surprise, it holds stuff.
Old Oct 8, 2006 | 03:11 PM
BlueBonnet's Avatar
BlueBonnet
Sounds like this belongs in the "things you didn't know about your mini" thread. Last time I took the hubcaps off I was too lazy to dig in around the battery and found they came off easily with a pointy tool that was just lying around in my tool box.
Old Oct 8, 2006 | 10:06 PM
ImagoX's Avatar
ImagoX
My lug wrench has a plastic tip like a big, flat blade screwdriver... It worked to get the caps off my X-lites. Is there something else in with the battery? I don't remmeber seeing anything in there, but maybe the cabrio's different....
Old Oct 9, 2006 | 12:26 PM
Crashton's Avatar
Crashton
Your Vert should have the same tool in the same place. It's a little bent piece of metal that hooks into the hole on the V spoke cover. WAIT a minute, your car came with S Lites didn't it? It's possible you don't have that tool.
Old Oct 9, 2006 | 12:33 PM
agranger's Avatar
agranger
I got the tool w/ my web-spokes where the lug-bolts are exposes all the time.
That styrofoam container looks like it is in there to wedge the battery into place. That's also where they hide the tow-hook.
Old Oct 9, 2006 | 12:58 PM
ImagoX's Avatar
ImagoX
Yeah, my OEM rims were S-lites, with no covers. I bought the the other rims from eBay for my All-Season tires. Now that I know what to look for I'll check. Thanks!
Old Oct 9, 2006 | 05:43 PM
MiniSuperCooper
Here's a pic of the tool.
http://c3club.org/builder/img/brakepads/DSCN2785.jpg
I found it on this thread which talks about how to change your brakes. Good stuff.
https://www.northamericanmotoring.co...ght=ebc+brakes
Old Oct 10, 2006 | 09:59 AM
jwardell's Avatar
jwardell
Sounds like the tool and location has changed over time.
In my 04, it is basically a metal wire bent 90-degrees for the last quarter inch, and the other end is looped around like a keychain for your finger (as pictured above).
It stores in the outermost part of the black and red mini toolkit pouch, which is mounted inside the leftside boot compartment with a velcro strap.
No styrofoam in my battery compartment.
Of course, you can use anything to hook in there and yank the covers off.
AdrenaliNate
Nov 4, 2015 07:26 PM
h0micide
Aug 27, 2015 09:17 PM
h0micide
Aug 25, 2015 12:19 PM
Aug 21, 2015 11:25 AM
