Suspension Strut Nut Help
Old Oct 6, 2006 | 12:09 PM
Ray59's Avatar
Ray59
Strut Nut Help
I'm replacing my upper strut mounts, and need to know if there is some trick to breaking the nut loose. This is the nut that holds the strut rod in the mount above the bearing. The rod has an allen key, the nut looks like urathane self locking. But it also has a couple of nicks in the top like I would need a punch and hammer to break it loose. Any suggestions.
Ray
Old Oct 6, 2006 | 12:28 PM
kenchan's Avatar
kenchan
you want to crack it loose while it's on the car (you won't need the
hex key to break it loose, just use a socket).
afterwards, there's a special socket to loosen the nut while holding the
hex key. i don't have that socket, so i dropped my 1/2 drive socket onto
the nut with no ratchet attached, dropped the hex hey through the socket's
1/2 hole, and used a channel-lock to turn the socket.
Old Oct 6, 2006 | 12:48 PM
Ray59's Avatar
Ray59
Thanks, it came apart way to easy. I'll put it back together and try it.
Old Oct 7, 2006 | 12:41 AM
cyates's Avatar
cyates
Simple tool for strut nuts
BMW makes a special tool to do this but it is so expensive the counterperson was embarrassed to tell me the price. I decided to create my own tool which will release the nut (with springs collapsed). I bought a deep 13/16" socket and took the Dremmel to it to cut a workable window to hold the hex nut with the hex wrench (note the cheater pipe to increase leverage).
Seems to work well and I can put a torque wrench on the modified socket to make sure the nut is on right.
Last edited by cyates; Oct 7, 2006 at 01:42 AM. Reason: Attach pictures of tool created
Old Oct 7, 2006 | 01:54 AM
cyates's Avatar
cyates
Problem posting picture
O.K. I'll post a few pictures when I figure out how to take an 800 x 800 JPEG picture.
Later.
Old Oct 8, 2006 | 05:32 PM
Ray59's Avatar
Ray59
Thanks I got it apart and replaced the strut mounts, they were pretty tore up. Also added a M7 strut bar which (has the tower reinforcements). Nice Stuff. Don't have to worry about mushrooming.
I would like to see the tool cyates made though. Thanks.
Old Oct 9, 2006 | 05:54 AM
kenchan's Avatar
kenchan
ray59, any picts of your new stb and your car?
YaTuSabe
Aug 23, 2018 11:41 AM
OutMotoring
Mar 3, 2017 06:29 AM
Keet
Suspension
Aug 30, 2016 03:46 PM
vetsvette
Oct 11, 2015 06:05 PM
Suspension Products
Oct 1, 2015 11:53 AM
