R50/53 Engine problems
Old Jul 31, 2002 | 01:49 AM
nhatch's Avatar
nhatch
Has any body experienced any problems with the engine when idling? This morning (it was a cold start though not bitterly) my Coop failed to start first time, I had to click it over about three times before it started and even then it was low on power. I got the end of the road (about 100 yrds) and when I put it back into first gear it lost all revs and then died. It wouldn't restart unless I had my foot on the gas. For the rest of the journey I had very low power when changing up gears. When I was stationary I had to keep reving the engine heavily to avoid it cutting out.
My coop is only three weeks old.
Old Jul 31, 2002 | 01:58 AM
BoyRacer's Avatar
BoyRacer
:evil:
Old Jul 31, 2002 | 12:25 PM
MINIclo's Avatar
MINIclo
7th Gear Gal
Sorry to hear about your MINI's troubles. Please keep us posted as to what you find out & the fix.
Cheers!
Clover
Old Aug 6, 2002 | 06:27 AM
nhatch's Avatar
nhatch
I've got my car back, there was a fault with the throttle housing unit. It wasn't interpretating the revs correctly, when cruising at high revs it would reduce power to the engine. I did ask the dealer if it could of had the reverse effect give too much power when cruising at low revs, he didn't give me a definitive answer but i'm sure the answer if he was truthful would be yes. He said it was a one off incident.
My car had a lovely clean (inside and out).
Old Aug 6, 2002 | 08:31 AM
Tollag's Avatar
Tollag
I'm happy to report that while for a few days it seemed I had a simmilar problem with my S, it seems to have cured itself!
Old Aug 6, 2002 | 10:10 AM
CMINIGO's Avatar
CMINIGO
Mine nearly stalls (it has) when at idle/stop with the air conditioning on. This is not normal and is not because the engine is tiny like I thought originally! Supposedly there is a software fix coming out in September to fix the emissions regulator being too strict and cutting down on power way too much. It's only noticable when it's hot with the a/c on in most cases. I'm still waiting to hear back from MINI on this. I'll let you know if it really is a software fix.
Kimolaoha
Jul 5, 2023 01:04 PM
alistaircookie
Oct 8, 2015 10:52 AM
Zettinger
Aug 25, 2015 04:04 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
Aug 12, 2015 01:24 PM
