D Stock Front caster adj. in 05' Cooper S
Old Aug 17, 2006 | 08:23 PM
Darth MINI's Avatar
Darth MINI
Is this adjustable, and if so, has anyone experimented with it?????
Old Aug 17, 2006 | 10:26 PM
Mugami's Avatar
Mugami
Coordinator :: River City Minis
from what i understand Caster is adjusted by moving the top of the shock forward or backwards. and ajustment not found in stock trim. I've just recently put the Notec Front Camber and Caster plates and have started to "Play" with the Caster setting. The Stock setting is about Posi 4 deg. currently I've changed it to posi 4.7 degs (run in SM btw). This should give the car some more inital turn in and will cause a bit more push coming out of the corners which is what im looking for. Oh and btw if you talk to me i get Posi and Neg caster backwards all the time. Posi caster is moving the top of the shock towards the back of the car.
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
