Does the JCW brake kit come with SS lines?
Yep, what Todd said. With stainless lines you get more feel, a firmer pedal, and suchlike. With just the JCW kit without stainless lines, after it was broken in, I felt a more aggressive initial bite and quite a bit sharper braking. How much of that was Hawthorne effect I don't know for certain, but it stands to reason that bigger front disks and more aggressive pads all around would produce that effect.
Oh, yeah, and as someone else noted, I hope you like anthracite wheels. Whatever color your wheels are now, the fronts will be anthracite in a week. As far as I know nobody makes alternative pads for the JCW fronts. If I had realized that when I was shopping I might have made a different decision about the brakes.
Prior to doing the full JCW brake upgrade I decided to do a "phased in approached". First I installed SS brake lines and the metal bushings on the calipers. The difference while not dramatic did elminate all the things I didn't like about the stock brakes. Just doing what I did got rid of the soft pedal feel and sortened response times. After completing the job I drove my car to the Nurbergring and had a blast the brakes while not perfect were certainly worth the cost of the improvement. Also I have white wheels so I use EBC Greens, for now I think I have a great set up, the only thing that is preventing me from doing the JCW upgrade is what I have now seems to be a big improvement over stock, way cheaper and keeps my wheels clean. If someone comes out with low residue pads for the JCW brakes I will do the JCW upgrade at that time. I guess I am bit of clean freak!
Dec 23, 2015 10:36 AM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
