Cams and Heads (MC)
Cams and Heads (MC)
What is the stock cam duration/lift?
What is the Schrick cam duration/lift? Search came up unclear, but possibily 260/260.
Degrees of overlap between the two?
What are the differences between the MCS and MC OEM heads?
MCS cam in MC?
MCS cam in MC?
I dunno about the stock cam's lift/duration...
The MC Schrick cam is 260/260 - not sure about overlap. I can say that it's silky smooth at idle and really, REALLY rips from 3.5K to redline.
There is NO difference between the MC and MCS heads EXCEPT for what the valves are made of... the MCS head features Inconel valves, which the MC's valves are plain old stuff.
The stock MCS cam is the same as the MC, which is also the same as the JCW cam... They're all the same... So yeah, you can use an MCS cam in an MC - but it won't do you any good.
