Bleeding Clutch Slave Cylinder
Old May 12, 2006 | 07:24 PM
CabMike's Avatar
CabMike
I'm trying to bleed the clutch slave cylinder and not having much luck! I have been using the standard brake bleeding technique of pumping the pedal, will this work with the clutch? What is the trick to this that I'm missing? I've made sure that the brake fluid is completely topped off as I know the clutch gets its fluid from the brake resevoir.
Thanks,
Mike
Old May 13, 2006 | 08:46 PM
002's Avatar
002
A vacuum pump has worked best for me. You are also supposed to completely compress the slave cylinder with a special tool (you can make this), but I have done it both ways. Using the manual brake bleed method is the last resort as it is hit or miss, but if you must, try disconnecting the slave cylinder and pointing the bleeder up like a syringe to get the air out.
Old May 14, 2006 | 07:28 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
With BMW's, I've always, connected the slave cyl nipple to the front left brake nipple, opened both, then stepped on the brake pedal. Never failed me. What would be different with the MCS?
Old May 17, 2006 | 05:34 PM
NC TRACKRAT
Veteran: Navy
Like a moth drawn to a flame, I just got through bleeding the clutch slave cyl. If you're not mechanically inclined, I suggest, in a word, DON'T! For me, traditional method of using a Mighty-Vac didn't work and I got air into the system. After taking out the 2 ea. 10mm bolts, had to fab a tool similar to the factory's which compresses the piston, then using a pressure bleeder, finally got all the air out after 3 sessions. At least I'm an expert(has-been under pressure) now.
Old May 17, 2006 | 05:55 PM
onasled's Avatar
onasled
I agree, don't mess with the slave cylinder. For some reason it's not as easy as it should be. I messed mine up and then it leaked. Fortunately my dealer replaced it under warrantee.
ShadyCoop
Sep 20, 2015 08:57 AM
Sep 16, 2015 06:22 AM
Sep 16, 2015 06:18 AM
msusparty1985
Sep 13, 2015 02:10 PM
wildwestrider
Sep 4, 2015 06:25 AM
