4th Annual MINIs on the Dragon (2006) Ready to take your turn trying to tame the Dragon? Learn all about what will likely be one of the largest MINI gatherings in 2006.
I-40, section to be avoided?
Old Apr 30, 2006 | 09:31 AM
mmatarella's Avatar
mmatarella
I've searched and can't find the message. Someone with local knowledge suggested a section of I think I-40 that should be a voided... Due to contruction and a lot of stone etc. loose to be kicked up. Now I can't find it.
Anyone with local knowledge care to kick in?
Old Apr 30, 2006 | 10:22 AM
Edge's Avatar
Edge
AdMINIstrator
Mark, Wiggles was the person who posted some alternate directions to bypass that construction - I have transposed his directions into a Word document, including trip miles and cumulative distance.
I'll email them to you!
Old Apr 30, 2006 | 12:46 PM
MyCarV's Avatar
MyCarV
Are you referring to the following? I'd love to have the mileage emailed to me also, as well as the directions to Fontana Village coming that way if you got them already.
Originally Posted by Wiggles
As a local, might I suggest, that those coming from the North, (I-81S - I-40W)
1. Get off of I-40w at Exit398 (Strawberry Plains Pike) and go LEFT.
2. Follow Strawberry Plains Pike to E. John Sevier Hyw. and go LFET.
3. E. John Sevier Hyw. turns into W. John Sevier Hyw.
4. Follow W. John Sevier Hyw. to Maryville Pike (Hyw.33s) and go LEFT.
5. As you cross S. Washington St. in Maryville, Hyw.33 becomes Hyw. 411s.
6. Follow Hyw. 411s until the merge with Hyw.129.
This route will get you around the considerable construction (and delays) going on in Knoxville on I-40w. (the last 2 times I have taken I-40w through Knoxville the front of my MINI has been damaged by rocks and dirt. )
If you are coming in from the South or West, construction is not an issue.
I hope this helps.
Old Apr 30, 2006 | 01:28 PM
Edge's Avatar
Edge
AdMINIstrator
Yes, those are the directions, I just wrote out (and calculated) them in a MapQuest-style format.
Email sent!
Old Apr 30, 2006 | 04:21 PM
o4amini's Avatar
o4amini
Thanks for posting this tip on travel for those of us coming from the north
Old Apr 30, 2006 | 08:01 PM
Va_Bene's Avatar
Va_Bene
Email sent!
If you have a chance I'd love to get those via email as well. Thanks!
Old Apr 30, 2006 | 08:06 PM
Edge's Avatar
Edge
AdMINIstrator
Sent!
Old Apr 30, 2006 | 10:06 PM
davisflyer's Avatar
davisflyer
I just travelled on I-40 from Raleigh to Knoxville and back last week and encountered NO construction. Kinda fun through the mountains too, even though we were travelling in the mini-van !
Old Apr 30, 2006 | 10:19 PM
CSAMF's Avatar
CSAMF
Which way is quicker????
So now that the construction is over, which way is quicker?????
Old Apr 30, 2006 | 11:11 PM
Edge's Avatar
Edge
AdMINIstrator
That's a very good question... I PMed Wiggles, the gentleman who originally suggested the detour, to ask for his confirmation that the construction delays are no longer a factor.
I'll report back what he said, unless of course he posts it in here anyway.
Old May 1, 2006 | 05:07 AM
MAJMattMason's Avatar
MAJMattMason
Well, I just drove I-40 from Barstow, CA to Memphis, TN and can tell you that the section right around Albuquerque, NM is to be avoided. Although, seeing as how you live in Alexandria, VA, I would suggest a much shorter route to the Dragon. It is not necessary to drive through Albuquerque.
Old May 1, 2006 | 05:43 AM
Edge's Avatar
Edge
AdMINIstrator
There is still some construction starting at the Cherry Street exit. Not as bad as it was when I posted before. There still is a lot of sand and gravel on I-40 going through Knoxville. However I would still take John Sevier Hwy. around Knoxville because it is faster. The route I posted is the way I always go.
Here's a good link to help you decide which way you want to go.
http://www.tdot.state.tn.us/tdotsmartway/default.htm
So, with that in mind, I'm still going to lead my caravan on the alternate route.
As for you, MAJMattMason... impressive drive... I don't envy how tired you must be from that... but thanks for the "avoid Albuquerque" tip - very funny heh.
Old May 1, 2006 | 05:47 AM
thatatvguy's Avatar
thatatvguy
If you are coming down I81, you could also take the new I26/US23 road that goes from the TN - NC state line to Asheville. It cuts off a lot - imo. You would not even have to go to toward Knoxville. You pick it up just south of the Bristol Johnson City area. Then you would pick up the directions like you would be coming in from the east - US74 I think. This would bypass the "gorge" as it's called.
I think that a lot of the new maps are not listing it yet b/c it's not been "officially" renamed, but it's there. Just watch your speed - new road means ticket happy cops.
Old May 1, 2006 | 07:21 PM
Smokey's Avatar
Smokey
Yup I-26 does save some distance and depending on the time of day it'll save some time also
The NC side of the road is all finished and not that well patrolled - just one Trooper around Mars Hill area and then again coming into Asheville. If you are coming this way plan to come through Asheville before 3:30 / 4:00 pm. They are redoing a bridge on the west of Asheville (exit 44) and this is the same spot where I-40, I-26 and I-240 join. We locals call it "Malfunction junction", you will come to a complete stop if on this road within 9 miles of the interchange on most workdays around 5:00 pm.
We used I-40 through the gorge last weekend and although they are still fixing the shoulder around NC mile marker 5 on the East bound side there was no delay and no stopped traffic at all. There were however 2 of NC's finest and 1 of TN's finest patrolling the roads.
Those of you taking Hwy 74 west from I-40 to the Dragon; watch out from Waynesville to Balsam Gap (about 10 miles) and again at mile markers 83 and 81 (Sylvia and Franklin exits) they like to sit and relax there also.
Old May 1, 2006 | 09:23 PM
Edge's Avatar
Edge
AdMINIstrator
Curiosity about the vast difference between Google Maps and MapQuest
thatatvguy and smokey4...
I'm very curious about the results that Google Maps display when giving directions, compared to MapQuest. Let's use my example.
Try this:
On BOTH websites, get directions from simply "Annandale, VA" to "Fontana Dam, NC". That's it (no street or house number).
The difference between the sites is vast!
MapQuest suggests staying on I-81S until I-40W, then getting off on 128 and taking it down. The more "traditional" way. 543.18 miles, 8 hours & 58 minutes.
Google Maps suggests taking the I-26/23 exit from I-81S and heading the way suggested by you guys... the trip distance is 552 miles (slightly longer) but a time measurement of 12 hours and 2 minutes! That's only 9 miles longer but 3 hours time difference!
Is it simply because their data is old, and the road is much faster now (i.e. faster speed limit, fewer lights?).
Old May 2, 2006 | 01:53 AM
Smokey's Avatar
Smokey
That's got to be a glitch in their mapping program.
Streets & Trips has the difference at only 33 minutes.
VA to Knoxville down 129 to Lake Fontana: 542.4 @ 8 hr 55 min
VA to Johnson City to Asheville to Lake Fontana: 547.7 @ 9hr 28 min
Then again S&T showes the road from Johnson City to AVL as being the old Hwy 19 not the new I-26. BTW I had to force the software to give me the JC/AVL routing. When I entered just VA/AVL/Fontana it gave me I-95 to I-40 and I wouldn't wish that on anyone!
I will tell you that distance doesn't mean much around here when you figure travel time.
Whatever you do be carefull out there and enjoy the trip!
Old May 2, 2006 | 05:30 AM
thatatvguy's Avatar
thatatvguy
You can't beat the mix of a good ole' paper map with some road knowledge and a hint of adventure.
Old May 2, 2006 | 06:42 AM
fillelectrique's Avatar
fillelectrique
uggg, that's one of the highways that i feel i'm going to die on. HATE I-40.
Old May 2, 2006 | 07:52 AM
thatatvguy's Avatar
thatatvguy
Yep, there's nothing like a concrete wall on one side and a 18-wheeler on the other! Ha ha.
Old May 2, 2006 | 08:44 AM
Smokey's Avatar
Smokey
Which is why I couldn't avoid the 24 foot double extension aluminum ladder that was lying in my lane.
Of course the other cars were able to straddle it with more then enough clearance. Myself on the other hand, was unable. Thankfully it was laying straight and still on the ground when I went over it. Took out the lower valance, rad support, skid plate, inner fender well and a few other little items.
Ran about $1400 in parts and labor. Great things was the owner of the ladder was standing on the side of the road waiting for a break in rush hour traffic to try and get the thing out of the way; so his insurance covered it.
Vaderm34
Chicago MINI Motoring Club
Sep 28, 2015 05:03 AM
BMC_Kid
Sep 27, 2015 04:31 PM
Olenska
Sep 18, 2015 09:24 PM
