R56 MC and MCS turbos for 07?
Originally Posted by Zman
i recently read that the mini one will be normally aspirated, and the MC and MCS will be turbo engines in the U.S.
true?
true?
MC will be turbo also?
Topping the new MINI range will be three engines pumping out around 115, 140 and 170 bhp (the latter belonging to the new turbocharged Cooper S). All versions of the new engine include variable valve timing, composite camshafts, and an `on-demand’ water and oil pumps. The engine will be lower and wider but will weigh in at a respectable 120kg (in Turbo form). The 140 and 170bhp versions will include a twin-scroll exhaust turbocharger that will virtually eliminate turbo lag.
Is the U.S. gettign the 140/170 HP engines (MC and MCS)? the article i read stated that the normally aspirated 115HP was for UK.
Originally Posted by Gabe
All you ever wanted to know: Motoringfile.com: Next Generation MINI Revealed
Drivetrain removing heat shields for turbo cat ?
rckrzy1
Aug 11, 2015 06:06 PM
Aug 11, 2015 09:01 AM
