P1242 engine code set
Old Mar 25, 2006 | 09:46 AM
Trickle X's Avatar
Trickle X
I read my codes and have a P1242 code set. I have the list, but alas its on my other computer & I am no where near it. Does anyone have the link to the Pcode lists?
Thanks....
Old Mar 25, 2006 | 09:49 AM
Motor On's Avatar
Motor On
Need a Bently owner to check for the details but my code look-up comes back as Manufacturer Air Fuel Metering.
Old Mar 25, 2006 | 10:24 AM
MSFIT's Avatar
MSFIT
nvm
Old Mar 25, 2006 | 11:09 AM
Cooper_Si's Avatar
Cooper_Si
Hope this helps...
P1242 4674 Secondary Upstream Manifold Air Pressure Sensor Too High in Deceleration
Old Mar 25, 2006 | 12:01 PM
MSFIT's Avatar
MSFIT
Originally Posted by Cooper_Si
Hope this helps...
so your boosting too much when you let off the gas. your bypass valve is not working properly, or your wastegate
Old Mar 25, 2006 | 12:29 PM
Trickle X's Avatar
Trickle X
Yup that sounds rite.....I went ahead and tied shut the BPV & it didnt kick the code again.....
I will adjust the blow off valve next, as its all the way soft...
Thanks guys!
Old Mar 25, 2006 | 01:28 PM
Cooper_Si's Avatar
Cooper_Si
Cheers matey
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
mdutton11
14
Oct 26, 2015 01:47 PM
David.R53
Sep 1, 2015 06:49 PM
minipopkart
Aug 13, 2015 05:22 AM
