pilo intake
Old Mar 18, 2006 | 05:54 PM
mightydread's Avatar
mightydread
pilo intake
hi all, i just installed a pilo intake . is it ok that i removed the plastic heat sheild .i'm triing to get more air to flow.
mikie
Old Mar 18, 2006 | 05:58 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
MightyDread is worried about water getting to the ECU...
We checked it earlier today, and the Alta heatshield kind of wraps around the ECU cover, where the Pilo one stops right besides it.
We all know removing the "back-panel" gets more fresh air to the intake filter, but any risks of removing it on a Pilo intake?
Thanks guys for any help!
Old Mar 18, 2006 | 07:13 PM
SB's Avatar
SB
I have the Pilo and instead of removing the panel. I added a hole to it to see if I could get more performance. I have not noticed an increase in performance, maybe 1/2 hp if I put it on a dyno , but the sound is closer to what an Alta sounds like. I have not noticed any water even when washing the car and intentionally spraying water in the cowl vent.
Old Mar 18, 2006 | 07:33 PM
DarkMiniCooperS
So I guess completely removing it on a Pilo is just like with a Alta kit...?
On my car, with the Alta intake, I removed it, and there's no water coming in at all... The only worry of MightyDread is that water might get into the ECU from the windshield vent.
I guess the only way to get water in there would be to drive in reverse, at 6000RPM+
Old Mar 18, 2006 | 07:46 PM
SB's Avatar
SB
That, and have someone on the hood spraying water into the vent.
I'm not saying it will not see water with the partition completely removed. Just that with the way I did, I'm not seeing any water.
Old Mar 19, 2006 | 05:30 AM
mightydread
thanks guys i made some holes in it hopefully this will work.
Old Mar 19, 2006 | 06:42 AM
kenchan's Avatar
kenchan
^^ yikes... i'd clean up those holes....
i thought eric over at helix13 sold those drilled walls for real cheap.
Old Mar 19, 2006 | 07:01 AM
mightydread
any idea where i can find them on his site.
thanx
Old Mar 19, 2006 | 08:03 AM
MINIAC's Avatar
MINIAC
MINI Madness sells one ...
http://www.mini-madness.com/index.as...ROD&ProdID=174
Old Mar 19, 2006 | 10:48 AM
jblow's Avatar
jblow
thanx
Look in the "used" section. Alternatively, here's a DIY from Webb Motorsports from some time ago:
http://store.webbmotorsports.com/for...ht=airbox+cowl
Old Mar 19, 2006 | 01:01 PM
Malcon's Avatar
Malcon
you could always get some weatherstripping and seal the ecu box?
Old Mar 19, 2006 | 02:00 PM
mightydread
[quote=jblow]Look in the "used" section. Alternatively, here's a DIY from Webb Motorsports from some time ago:
http://store.webbmotorsports.com/for...ht=airbox+cowl[/
thanx jblow , looks like i just got to make bigger holes.
thanx again guys for your help.
mikie
Old Mar 19, 2006 | 02:32 PM
qwertmonkey's Avatar
qwertmonkey
mikie
I dont have a heat shield and mine is just fine!
rtk90
Aug 29, 2019 09:08 AM
67morris
May 7, 2016 11:52 AM
Sep 22, 2015 02:05 PM
knbond1
Sep 22, 2015 06:20 AM
Sep 11, 2015 11:09 AM
