Mirror vibration
Old Mar 12, 2006 | 04:05 PM
rjmann's Avatar
rjmann
Mirror vibration
My rear view mirror has started to vibrate every so slightly which makes all vision thorugh it appear fuzzy and slightly out of focus. If I lightly touch my finger to the bottom of the mirror housing it stops and the view is again sharp. Before I pulled it apart, I figured I'd ask if there is some way to adjust or tighten the joint that holds the mirror in place?
Old Mar 12, 2006 | 04:41 PM
BBCooper's Avatar
BBCooper
Same here...
You are not alone on this one... I see the same vibration in the rear view mirror espically when slowing down through the rpm range 3000 & less.
I have attributed it to the overall design of the windshield and the mounting for the mirror itself. As you mention a slight touch is enough to take the "shake" off the mirror. This is really changing the resonance frequency of the mounting.. So perhaps making it lighter or heavier will shift the shake to a different (and hoepfully less occuring) frequency..
If/when your changes result in an improvement, please send back an update on what you did.
Old Mar 12, 2006 | 05:27 PM
rjmann's Avatar
rjmann
Well you've given me a horrible idea. I'll let you know if it works out.
Old Mar 12, 2006 | 07:00 PM
usaaus's Avatar
usaaus
Mine vibrates a lot with the HK turned up!
Old Mar 12, 2006 | 07:10 PM
Motor On's Avatar
Motor On
I have the same issue on occasion, I think it goes away when you dump the runflats!
Old Mar 12, 2006 | 10:07 PM
BBCooper's Avatar
BBCooper
Just for the record..
For what its worth.
I dropped the runflats & the S-lites and still see the problem..
Interested to hear what the "horrible idea" was..
Later..
gar56
Nov 15, 2016 06:41 AM
vulkandino
Oct 31, 2015 08:29 PM
minieater
Oct 28, 2015 02:15 PM
penguinplf
Oct 11, 2015 07:36 PM
MCSNY
Sep 29, 2015 10:17 AM
