Suspension Rear trailing arm bushing - an important FYI
Old Mar 6, 2006 | 10:30 AM
meb's Avatar
meb
Apparently Mini/BMW have changed not only the 05 rear trailing arm bushing, but the entire trailing arm and hub carrier are different. I cannot find out why.
If any of you are in the process of tinkering with bushings for this trailing arm, Powerflex has the new 05 bushing, but none of the distributors in the USA has one yet.
Another path:
Jeff Ireland - Ireland Engineering - will make bushing inserts for me for a set-up cost. They already have inserts available for pre 05's. I've used inserts in the past with great results. These do not require pressing bushings in or out. Simply un-bolt, install the inserts left and right and bolt back up.
Old Mar 7, 2006 | 04:08 PM
pure&simple's Avatar
pure&simple
I thought I remembered someone reporting that their car was unstable under heavy braking with a stiffer rear bushing setup, so I found the thread... https://www.northamericanmotoring.co...ad.php?t=60601
I would be interested to hear whether you experience this problem with the inserts... please let us know how it goes!
Old Mar 7, 2006 | 04:19 PM
meb's Avatar
meb
Pure&simple,
Thanks for the reminder. John Petrich and I occasionally exchange PMs. I forgot about his experiment. I sent hima PM regarding this.
Jeff Ireland told me that the rear bushing does allow a certain degree of ride steer, not a welcome trait. But correcting ride steer may also un-do some other suspension subtlties that affect extreme braking stability??? However, Jeff Ireland was unaware that BMW/Mini altered the bushing design post 04. I'm not sure if there were problems with the earlier bushings, or if this alteration is designed to enhance comfort. I dunno and know one that I've talked with knows. But thanks for the reminder again.
Michael
Old Mar 9, 2006 | 08:45 AM
pure&simple
Sure thing. If your results are good, I'll probably be doing this mod too. Always on the lookout for ways to make a good suspension setup even better.
Old Mar 9, 2006 | 09:44 AM
meb's Avatar
meb
Jeff Ireland is infact making these. The hardness or durometer is between 80-85. These are inserts for both sides fo each bushing; unbolt, install and bolt back up.
It'll be a few weeks. I won't be able feel how this modification works by itself; I'm installing all the goodies at once.
Toolman
Jan 20, 2016 06:50 AM
wkp1219
Nov 13, 2015 07:52 AM
maestro39
Oct 27, 2015 02:38 PM
JPMontes3
Aug 23, 2015 01:26 AM
Minibeagle
Aug 13, 2015 10:00 AM
