LSD Oil?!!!!!!
Old Mar 3, 2006 | 10:45 AM
CARdiac's Avatar
CARdiac
LSD Oil?!!!!!!
OK, I am a little upset. My dealer changed out the flywheel and clutch in December and my LSd started making some noise so I took it in. The noise was similar to the noise produced at full wheel lock (turning) but was produced with only a slight turn. I recognized/suspected it to be a lack of the LSD additive in the oil. Low a behold after chaning the wheel bearings and tie rods they changed the oil and the noise went away. They said there was no metal shavings in the oil when changed.... but would that show the damage? What problems should i look for? Will I have problems with the LSD in the future? WE drove w/o the oil for 3 months (approx 2K Miles) how much damage was done?
Old Mar 3, 2006 | 10:55 AM
Dr Obnxs's Avatar
Dr Obnxs
No clue BUT
Make sure there's a record of the screw up in your service log. And write a letter to the dealer discussing the issue, and keep a copy. Then if you have issues in the future, you'll have some leverage.
Matt
Old Mar 3, 2006 | 11:18 AM
06_SuprCooper's Avatar
06_SuprCooper
hmmmmm... what kindof sound when you turn the wheel? mine makes a kindof "rubbing" noise when the wheel is turned half a turn either way from straight. when its cold the noise is louder. think it might be a oil problem?
Old Mar 3, 2006 | 11:36 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
so let me get this right...they drained your oil to change a clutch...but never filled it back up?? so then you drove around for 3 months with no trans fluid in the trans? if this is the case, i would ask for a hole new trans. on there dime. good luck.
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Mar 3, 2006 | 02:15 PM
Dr Obnxs's Avatar
Dr Obnxs
Not quite...
Refilled the tranny, but didn't put an additive package in.
Matt
Old Mar 3, 2006 | 02:40 PM
Shea's Avatar
Shea
What kind of additive package? More info please!
Old Mar 3, 2006 | 02:50 PM
Dr Obnxs's Avatar
Dr Obnxs
It's probaly a friction additive package for the LSD... Don't know because I have and 02!
Matt
Old Mar 3, 2006 | 02:53 PM
not-so-rednwhitecooper
Yeah, any car with Limited slip or a Posi, you need a special additive.
Old Mar 3, 2006 | 04:44 PM
Rossii's Avatar
Rossii
Its the same oil they use in the M3's. Initial M3's had the same noise problems.
Old Mar 3, 2006 | 08:44 PM
CARdiac's Avatar
CARdiac
Matt
Thank you, I will press the SA for documentation... I will also send a letter.
No, just the additive was left out
There is a special additive for lsds, not sure what it is....
When I first got the car ther was a rubbing noise at full steering lock (normal) but it started to occur with only a slight turn of the wheel. Have you ever driven a 4x4 in 4WD? If you have a true 4X4, where you can put the transfer case in low gear and lock the differentials... do that and try to make a tight turn... that is the sound... not the wheels squeeling but the metalic rub/low pitch whirrin noise.
CardinalsRule
Jun 11, 2016 04:34 PM
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
Sep 10, 2015 12:34 PM
Anakist
Australia
Sep 8, 2015 03:32 AM
Sep 2, 2015 09:05 AM
Ladybug-S
Sep 1, 2015 07:07 PM
