M7 SRP Tech Paper.......
Old Feb 19, 2006 | 05:56 PM
M7's Avatar
M7
Some of you asked for it and here it is.
Our own Will has worked diligently to put together an easy
to understand technical analysis of what the patented
M7 Strut Re-Inforcement Plate will do for your MINI.....
Strut tower deformation, also known as mushrooming, is one of those problems that continues to plague MINI owners in all drives of life, from track cars to cruisers. It seems like the sheet metal that serves as the mount for the front strut towers was made far too weak for the strength of the suspension. If the mushrooming is drastic enough, it can affect the behavior of the car. Many MINI owners have had to take a 2x4 and a hammer to their strut towers to bang the metal back into place.
The deformation occurs either over time through continuous small events or sometimes all at once with a large event. Likely events can include bottoming out the suspension due to catching air, running off the road or track, or even hitting a large pothole, among other things. All of these conditions impart a force on the thin metal that holds the strut tower that it was obviously not designed to withstand. Using finite element analysis (FEA) software, we can analyze the effects of large forces on the strut tower.These first two images show the relevant pieces of a simulated strut tower. Some of the model has been suppressed to make it easier to see. This model is not meant to be completely accurate with respect to the Strut tower of the MINI, however the shape and contact points are approximately correct and the properties of the materials are accurate.
From the factory the strut tower provides a flattened surface for the strut to rest against. This is important for maintaining straight alignment and proper suspension geometry. Using this model, we simulated an extreme case of the “car” essentially being dropped, as if it were to have jumped off the ground or fallen off the road. The deformation is readily apparent, but to make it easier to see we have enhanced the deformation to make it easier to see. The following image are the results of that fall. Following to see, will be a colored image. The color shows the amount of displacement from the original position. Blue means little or no displacement, moving towards red which is the maximum measured displacement.
It is apparent that a hard impact to the strut tower from below will deform the metal. This has been seen on many MINI’s in the last few year, and this simulation serves only to validate the effect. While the mushrooming of the strut tower is not something that is guaranteed to happen, given the frequency of the effect it is definitely something to be mindful of
M7 is mindful of strut tower mushrooming, and has developed a solution that will help prevent it from happening. The Strut Re-inforcement Plates bolt to the strut tower using the stock bolts that hold the strut in place, sandwiching the thinner sheet metal between two more rigid pieces of metal. This sandwich serves to distribute the force of an impact over a much larger amount of metal, resisting deformation. The following two images show the same simulated strut tower with the SRP’s installed.
The SRP equipped strut tower was then exposed to the exact same impact force as the preview, non-SRP model. The results make a very strong case for the advantages of having the reinforcement plates installed. not equivalent to the previous colored images. The same green or red color does not equal the same deformation from pre-impact in the two sets of images.
As you can see, mushrooming is almost completely prevented, even in one of the most extreme cases we could simulate. Even with the deformation enhanced, it is difficult to see the mushrooming occurring with the SRPs installed on the strut tower. Even in less extreme instances, it is clear that you can protect the integrity of your strut towers using M7’s Strut Tower Reinforcement Plates. The M7 strut tower bar provides the same protection with the added benefit providing extra structural rigidity to your frame. The only question now is which product is right for you?
peter
Team M7
562-608-8123
GregoryK
Dec 14, 2015 01:34 PM
boholio
Nov 9, 2015 03:50 PM
gnhovis
Sep 28, 2015 10:56 AM
rikaro
Sep 21, 2015 06:57 AM
HJCPmeek
Sep 15, 2015 01:59 PM
