o2 Simulator for MINI?
Old Feb 18, 2006 | 11:52 AM
neilgj's Avatar
neilgj
So, I saw the posting in the vendor area. I see the words o2 and simulator and I think, this has got to be something that's probably illegal to circumvent pollution control equipment. The web site offers no real explanation - except perhaps to the fully initiated. I'm sure it's not illegal and that it's an absolutely wonderful product.
Having said that, though, can someone explain what this gizmo is and why someone might find it desirable? Thanks!
Old Feb 18, 2006 | 03:54 PM
BFG9000's Avatar
BFG9000
It's a bogus 2nd oxygen sensor that always claims everything is A-ok. It's purpose is to prevent a CEL when you remove the catalytic converters. Legal for "off road use" only.
Old Feb 18, 2006 | 04:43 PM
Rawhyde's Avatar
Rawhyde
It'll certainly do that! It'll also stop your Check Engine Light from coming on when/if the downstream O2 sensor fails. Although I haven't encountered a downstream O2 sensor failure on a MINI, I've seen about 10 times more downstream sensors fail than upstream sensors.
Rawhyde
Old Feb 20, 2006 | 10:27 PM
COR BLMY's Avatar
COR BLMY
I have a header with aftermarket cat
It throws a P0420 code ( Cat below threshold.)
I am thinking about one of these so that I don't miss other codes.
I would be happier to not have to do this
MINI MANIA says they are working on something to keep the sensor in place while not allowing the system to throw the code
Dec 23, 2015 10:36 AM
Dashdog
Aug 10, 2015 06:17 AM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
