grounding Nology Hotwires
Old Feb 6, 2006 | 02:43 AM
kidicarus13's Avatar
kidicarus13
For those of you that have installed Nology Hotwires on your car... where did you connect the capacitor ground wires? I couldn't find a decent ground. Help!
Old Feb 6, 2006 | 05:05 AM
SumWon's Avatar
SumWon
I used the rear mounts for the IC, close and secure.
Old Feb 6, 2006 | 05:35 AM
kidicarus13
I have a GRS intercooler so although there are no mounting points on the rear of the GRS I should still be able to mount them there with the bolts I took out (in the original holes) ...right? Your picture was helpful, thanks!
Old Feb 6, 2006 | 06:18 AM
SumWon's Avatar
SumWon
My only concern with using the rear mounts in that situation would be rubbing on the underside of the GRS. If that appears to be a problem, you could use one of those grounding kits that are floating around. PM 62Lincoln, last I knew he had one installed and was offering pictures.
Old Feb 6, 2006 | 07:34 AM
62Lincoln's Avatar
62Lincoln
I'm not sure it would work. The grounding points tie in to the chassis basically around the perimeter of the engine bay. It appears the Nology wires need a grounding point at or near the head (due to the length of the grounding wires). I'll still be glad to forward the pics if you think they might help, pm me and let me know.
Old Feb 6, 2006 | 07:38 AM
OldRick's Avatar
OldRick
Before installing Nology wires, you should read the Magnecor information about Ignition Cables on this page at Magnecor.
You won't get more power or better ignition from new wires, and the only real reason is if you like pretty colors around your engine. If you want pretty colors, I'd suggest Magnecor instead, as the Nology grounded design is useful mainly for demonstrating prettier sparks.
(I have no connection whatsoever with either firm.)
Old Feb 7, 2006 | 02:40 AM
kidicarus13
I already have the Nology wires installed, now it's just a matter of grounding them properly. I may just try a grounding kit.
Old Feb 7, 2006 | 09:09 PM
skuzy's Avatar
skuzy
is this grounding process the same with kingsborne wires? whats the isntallation process? i thought it was simply 'plug n play' .. am i missing somethign?
Old Feb 7, 2006 | 09:47 PM
SRLancer's Avatar
SRLancer
The Kingsborne wires are 'plug n play'. They are non-capacitive and don't need to be grounded.
Filmy
15
Jun 6, 2023 06:27 AM
Finhead
Electrical
Apr 12, 2019 04:05 PM
SJ-R50
Oct 28, 2015 08:39 AM
jennster
Sep 28, 2015 06:19 PM
