Suspension HELP ALTA rear upper control arm
Old Feb 2, 2006 | 06:20 PM
BLIZZ's Avatar
BLIZZ
I am installing Alta upper & lower rear control arms, and I just realized that the level sensor is mounted on the left rear upper factory arm. How do I handle this? Is there a mounting bracket I can get to mount sensor on new arm?
Old Feb 2, 2006 | 06:53 PM
onasled's Avatar
onasled
Hose clamp. Put a rubber sheet in between the controle arm and the mounting bracket and hose clamp. The bracket is the factory one you take off the factory arm.
Old Feb 3, 2006 | 05:46 AM
BLIZZ's Avatar
BLIZZ
Is it a critical adjustment or just possition the bracket as close to factory as possible?
Old Feb 3, 2006 | 06:36 AM
dominicminicoopers's Avatar
dominicminicoopers
Close is good. It's just the auto-leveler for the headlights.
Old Feb 3, 2006 | 07:59 AM
meb's Avatar
meb
...does this also double as the brake bias control sensor? you know, for those times when we stand the Mini on its nose at the end of a long straight
Old Feb 3, 2006 | 10:05 AM
BLIZZ's Avatar
BLIZZ
Thanks for your help.--I should be able to make a half pipe shaped bracket with u clamps. I just wasn't sure how critical the possitioning was & if I had to take into consideration the lower than stock height.
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
Toolman
Jan 20, 2016 06:50 AM
Minibeagle
Aug 13, 2015 10:00 AM
OutMotoring
Aug 6, 2015 09:32 AM
