MINI ID tags are in the mail....
Old Jan 25, 2006 | 08:19 PM
dragonflyer's Avatar
dragonflyer
Thnaks for you pacience guys. I just sent out about 20 or so ID tags and Actual Size stickers. You should get them in the mail in week or so.
This was the first batch and it was guite nice to see all the intrest. Keep them coming. If you need and ID tag sticker made up for you MINI you can get them right here.
http://www.aestheticreations.net/Stickers.htm
Old Feb 9, 2006 | 11:41 AM
dragonflyer
Now that all the IDs have been shipped out I seem to be getting a number of folks that the sticker is not sicking to the car.
If you have ahd that trubble and need a replacment please contact me. I will replace these stickers onece free of charge but there is a solution to the problem.
Instructions:
Before you put the sticker on your car there are a couple things you must do to prep the window. For some reason these windows have been coated with some type of wax or rain-x. Not on all cars but some. This must be removed before the decal will stick.
There are to options for cleaning the window.
First is using an Achohol and water mixter. you want 60% achohol and 40$ water. Spray the area real well and wipe with a microfiber towl. Use a little preasure when wiping to take some of the wax off.
Some glass can be more stubern than others. In this case you should use a claybar. You can find this at any auto parts store or Wall-mart. They are about $8. It's good to do this to the whole car once in a while to remove inperfections and wax build up.
The Claybar is a sure thing it removes everything but your clearcoat on your car. after that you should have no problem with your decal.
For everyone that has bought an ID sticker I will be sending out a new one. If yours went on OK then you get a second for where ever you want. If you had and issue than try the steps above before applying the new decal.
Cheers
ludedude
Aug 10, 2015 07:16 PM
Aug 10, 2015 01:59 PM
Dashdog
Aug 10, 2015 06:17 AM
