Navigation & Audio Have 2 stereo problems - help
Old Jan 18, 2006 | 04:06 PM
francois's Avatar
francois
I bought a used Mini with factory Ipod unit. It has two quirks:
- After the stereo has been on for about an hour, it just turns shuts off. Turn it back on and it's fine for another hour.
- When I turn off the engine, the stereo keeps playing.
These problems occur regardless of whether I'm using the Ipod or not. I'm going to open it up and have a looksie. Any ideas on what I should be looking for? Know which color wires are responsible for the bugs?
thanks,
francois
Old Jan 18, 2006 | 06:51 PM
GBMINI's Avatar
GBMINI
An hour or 20 minutes?
There are two "supply" wires to the radio - one is permanent and one is switched with ignition.
The radio can be turned on when only the permanent is present (ie: when the ignition is off) - but it will turn off after 20 minutes to save the battery.
If your car has a wiring issue with the ignition switched wire, it would of course not turn on/off wth ignition, and it would also turn off after 20 minutes.
Can't remember the pin numbers but you can find a drawing in the MINI2 FAQ
Old Jan 18, 2006 | 07:46 PM
francois's Avatar
francois
It could very well be 20 minutes. Time flies when I'm Mini-ing.
What you're saying makes sense. This behavior is good if the ignition was off. However it happens even when I'm driving the car. So I prob'ly have lines crossed.
francois
Old Jan 19, 2006 | 04:54 AM
petecrosby's Avatar
petecrosby
Did you wire it yourself or use the existing plug on the car's harness?
Old Jan 19, 2006 | 01:42 PM
francois's Avatar
francois
I took pins out of the harness to install the factory Ipod unit. The colors of the wires didn't match the directions exactly.
francois
Old Jan 19, 2006 | 06:07 PM
petecrosby's Avatar
petecrosby
francois
Ah, then it is quite possible that you have the two power wires reversed or the ignition-on wire is in the wrong place.
embiggenedmini
Oct 15, 2015 12:36 PM
rckrzy1
R55 :: Clubman Talk (2008+)
Sep 7, 2015 07:51 PM
tylewis
Sep 6, 2015 01:07 PM
Sep 2, 2015 11:15 AM
Sep 2, 2015 09:05 AM
