M7-srp
M7-srp
We listned to you.... And here's the new M7 Strut Re-enforcement Plate "SRP"
Thru the years, customers and friends with MINI's has had one common complaint....The strut towers mushroom after heavy impacts from shocks
and low aspect ratio tires. At a first glance the shock tower takes on a slightly
convex shape barely visible at a fist glance, but if you would compare the original sheet metal, you would find the horizontal plane has been moved
as much as 3/8" upwards, throwing the suspension out of any possible alignment fix.
The problem will most likely show up, as a slight pull either left or right
depending on which strut tower is buckled.
The M7 SRP will solve this problem by sandwiching the sheetmetal and shock
top plate, creating a homogenous top surface that will not bend,even during hard impacts.
Adding the SRP to your MINI, is an inexpensive solution to an expensive fix.
The plate is made from CNC machined aluminum,hard anodized black to prevent chipping, or oxidization.
Price: $109.00 for the pair.
Available right now.
Peter
Team M7
562-608-8123
Photograpy by DID
Peter
Team M7
562-608-8123
Photograpy by DID
