Navigation & Audio How can I get access CD Changer wiring on convertible?
Old Dec 22, 2005 | 12:17 PM
scatpack's Avatar
scatpack
Anyone know how or where I can get acess to the rear CD Changer wiring on a 06 Convertible?
Old Dec 22, 2005 | 02:30 PM
indimini's Avatar
indimini
You should be able to get to it by pulling the boot liner near the passenger side rear wheel. There is a single screw that you back out to remove the cover. Sorry, the picture's not better. But the changer cable should be in a bundle in this area. Once you have the rear cover off it should be pretty easy to find. Hope that helps.
Old Dec 23, 2005 | 08:43 AM
scatpack's Avatar
scatpack
Can you elaborate more?
I backed out the screw all the way (not off) and the washer stayed flush against the panel.
i tried to wedge the washer off but saw it wasnt budging.
After backing out the screw.. the panel pretty much wanted to stay put. Are you sure this is the only screw I need to remove? The panel is under the 'rollbars' and under the panel behind the lights.. it looks like I have to remove alot to get access.
Anyone been thru it before?
woodstudio
Mar 15, 2020 08:28 AM
turbobob
Aug 26, 2015 01:07 PM
atenzany62
Aug 26, 2015 09:26 AM
Zettinger
Aug 25, 2015 04:04 PM
