Suspension H-Sport Competition Package
Old Dec 7, 2005 | 06:17 PM
koenner1's Avatar
koenner1
Has anyone had any experience with the H-Sport Competition Package (25.5mm & 27mm anti-sway bars, H-Sport Springs)? If so how well does it handle?
Old Dec 7, 2005 | 06:25 PM
Byron's Avatar
Byron
H-sport competition package
I have both and i think there great.
Old Dec 7, 2005 | 07:24 PM
onasled's Avatar
onasled
It's probably one of the more popular setups. I used to run it myself and was very happy with ride and performance.
Unless you are doing some serious track days, I wouldn't recommend the larger front sway bar.
Also know that with any lowering spring there is the risk of destroying your factory struts. Otherwise it's my favorite road setup. (minus the front bar)
Old Dec 7, 2005 | 07:43 PM
weezer2282's Avatar
weezer2282
I will have the rear sway bar on this weekend and the springs in the next few months. I'm still thinking about whether I should put the springs on the stock struts or buy bilstein sp's or koni's. I would think it would be easier to swap out the entire strut and spring assembly.
Old Dec 7, 2005 | 08:25 PM
ScuderiaMini's Avatar
ScuderiaMini
i do not think that you will need the front sway bar, since the rear sway is going to stiffen the rear end, and make the car more neutral, you do not need to change the front sway bar.
Old Dec 8, 2005 | 03:52 AM
pmello's Avatar
pmello
I found some stock takeoff struts (FS: NAM) and bought all the parts to make them complete for some Eibachs springs. It really made the swap easy This also allowed me to keep the stock struts intact so I could swap them out for the winter in RI (even easier). I would recommend some aftermarket shocks to handle the extra requirements of the lowered springs if you have the bucks.
Old Dec 8, 2005 | 09:22 AM
gt6's Avatar
gt6
I had the H-Sport springs and comp rear bar on my '04 LY/LY and loved the set up. Remember the rear is adjustable so it's pretty easy to get the amount of over/under steer desireable. As for the springs, they were a fantastic upgrade as well. The ride was actually more comfortable after the springs were installed. I did quite a few track days with this setup, no autocross. I'll be doing the same with my '06.
RobbyD
Jan 29, 2019 01:22 PM
gar56
Nov 15, 2016 06:41 AM
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
Sep 29, 2015 12:11 PM
