Drivetrain Oil filter saga part II
Old Dec 5, 2005 | 05:47 AM
meb's Avatar
meb
Last time I checked in I complained about the oil filter housing leaking after every oil change - the O-ring breaks upon installation. Mind you, I've driven nearly 1.9 million miles so far in this life time, changed every filter myself with zero trouble.
Yesterday I performed another oil change. The filter was on correctly, and, the O-ring installed in its proper place. I replaced the old filter, but retained the old O-ring based upon a suggestion a month ago. I reinstalled the housing - this time I had no problem getting the housing to catch the threads. I tightened the housing down by hand and then gave a light snug with a 36mm socket - very light snug. Turned the engine on and it leaked like a mother. I took the housing off and the O-ring and filter looked fine. I installed a new O-ring and attempted to get the housing back on...it took 15 minutes of swearing before it caught the threads. Once the threads were engaged, I needed the socket to spin the housing on. Once tight the engine started with no leaks.
Every other time I replaced the O-ring, the filter leaked. Every oil change has consumed two O-rings; the first one breaks and the second one works.
I cannot figure this out. I change the oil every month based on my mileage. This is an absolute pain in the @#$^#^!!!!SS!!!!
Old Dec 5, 2005 | 05:54 AM
Soul Coughing's Avatar
Soul Coughing
this is my only idea, do you rub oil on the O ring before attaching it? could it be binding? Good luck
Old Dec 5, 2005 | 06:06 AM
meb's Avatar
meb
Yes, every time, with every filter on every car. Mobil 1 5W30.
I even used a light coating of high temp bearing grease in the past on the Mini...that didn't work either.
I've got a boat load of filters in my garage and no O-rings
Old Dec 5, 2005 | 08:28 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Did you try a new filter housing? If so, the next step would be to try a new oil cooler. If you need a new housing, I can send you one to try (just promise you won't mess it up like you did with the old one).
Old Dec 5, 2005 | 12:16 PM
meb's Avatar
meb
Andy,
I've made an appointment with my Mini dealer. Hopefully they can find the problem...and I hope it's me.
Appreciate the offer...but if it is me, yours won't work again
Kimolaoha
Jul 5, 2023 01:04 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
Lex2008
Aug 16, 2015 08:33 PM
Laura Redd Casler
Aug 15, 2015 09:32 PM
