Adjustable lower control arms
Old Oct 10, 2005 | 10:34 AM
MiniManiac74's Avatar
MiniManiac74
Has anyone put on the minisport adjustable lower control arms?? I have them and I didn't realize that you could not adjust them after you installed them. I am wondering if anyone has the technical data for these bad boys. What I am looking for is how turns equals how much change in camber. Anybody??
Old Oct 15, 2005 | 04:22 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
I don't have tech data but generally as you lower a mini you get more negative camber. If you haven't lowered your suspension you'd need more turns to adjust for negative camber. So stock ride height means less camber and lower ride height means more negative camber and less adjustment required by the lower control arms. See-
http://www.minifinity.com/index.php?...wtopic&t=13032
Old Oct 15, 2005 | 05:06 PM
MiniManiac74
Thanks. Someone on MiniMania told me that each 1/8 inch longer than stock equal .5 camber. I will go with that.
ebowling
90
Aug 4, 2019 09:15 AM
BRracing
Dec 22, 2015 09:25 AM
yukinoinu
15
Aug 24, 2015 09:20 AM
Minibeagle
Aug 13, 2015 10:00 AM
OutMotoring
Aug 6, 2015 09:32 AM
